tareko Occasional Visitor
Posted: Wed Feb 22, 2006 3:09 am Post subject: Tom Tom 700 help! |
hi all,
having some issues with this unit.
couple of Qs i hope can be answered.
thanks in advance
1. Can you delete the history of addresses you have been to?
2. Can you input other countrys postcode (germany) as i can only see uk and netherlands.
thanks |
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Wed Feb 22, 2006 7:52 am Post subject: |
1. no, only with resetting to factory settings.
2. yes, choose normal adress entry and just type in the postcode instead of the cityname _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
Oldboy Pocket GPS Moderator
Posted: Wed Feb 22, 2006 8:00 am Post subject: |
Hi tareko and welcome aboard.
1. The Recent Destinations are held in the .cfg File, found in the Map Folder. If you delete the File, TT will, on the next re-start, generate a new .cfg File. You will of course lose all your Personal Settings.
The list has a limited size, so if you keep adding new Destinations the oldest will fall off the end of the List.
2. There are only 2 countries in Europe that can pinpoint a few locations, within a few hundred yards, with a single Postcode. Other countries Postal References cover a larger area, that cover a complete district, which makes it no more accurate than inputting a Town/Village. _________________ Richard
Posted: Wed Feb 22, 2006 12:54 pm Post subject: |
thanks for that chaps.
i suggest they sort the clear history option out simple.
problem is, i tried entering a town where a holiday inn hotel is in berlin, and it cannot find it,
so in this instance what would i do?
thanks for your replys. |
Posted: Wed Feb 22, 2006 8:24 pm Post subject: |
Any chance of an address, so we can try it? _________________ Richard
Posted: Wed Feb 22, 2006 9:46 pm Post subject: |
HANS GRADE ALLEE 5
BERLIN, 12529
GERMANY |
Posted: Wed Feb 22, 2006 11:21 pm Post subject: |
All I can find is that that the place is called Schonefeld. The Postcode gets you close but the rest of the address probably refers to the Airport.
If you check on the Internet the Holiday Inn is at the Airport, which can be found on the Map with the POI.
Not a lot of help I know. _________________ Richard
Posted: Thu Feb 23, 2006 12:24 pm Post subject: |
cool thanks.
did you do a postcode search on the tom tom? |
Posted: Thu Feb 23, 2006 7:56 pm Post subject: |
I used the Postcode and it gave me several roads to choose from. I just picked the first (which happened to be near the airport). _________________ Richard
