Pocket GPS World :: View topic - cf vs. bluetooth vs gps mouse
keithc
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: cf vs. bluetooth vs gps mouse Reply with quote
I cannot make up my mind whether to buy a cf card, bluetooth or a wired gps mouse. Is there anywhere where I can see a comparison with pros and cons? I was thinking of the cf card however, i was told that in the car I would need an external antenna. Is this true?
Rgds
keith
The main differences are form factors and battery usage. The Bluetooth GPS Receivers will drain less power in general compared to a CF card. It depends if you need to take the GPS out of the car. If you don't, and you don't mind a cabled setup, then a mouse is the ideal solution as you have one accessory plug powering the receiver and charging the Pocket PC at the same time. If you want a cable less setup, a CF card is okay for out walking, but a Bluetooth Receiver is ideal.
You won't necessarily need an external antenna with a CF card, it depends on where you mount the Pocket PC, and also how steep your windscreen is. Some are okay. If you use a windscreen mount, then you shouldn't have much of a problem, but if you're using a vent mount, you'll probably need an external antenna. The objective is to let the receiver see as much of the sky as possible.
swan_g
I have a Globalsat, and an Arkon Powered Multimedia PDA Mount, this mount has a powered output, that can be used with the power cable that came with the Globalsat. This way, if I need to use the BT GPS with external power, that ads just 1 cable to the setup. And in addition, the Globalsat comes with an external antenna, which I haven't need to use it yet.
The GPS sits on my dashboard, and the least satelites I locked are 6 here in Miami (actually I got only 3 once, but I was stationary just under a highway).
Anyway... I'm pretty happy with the Globalsat...
Swan
icemanwayne
i purchased a ipaq 5450 and a navman 4400 bluetooth and yes it rocks,well worth the extra cash
flyingmanz
Well these are just my opinion
Pros
BT GPS receiver - Easy to set up, no wires needed, do not drain power from PDA
CF GPS receiver - Easy to set up, no wires needed, easy to carry
GPS mouse - Cheaper, charge GPS and PDA together
Cons
BT GPS receiver - Most expensive among all the choices
CF GPS receiver - occupy CF slot, drains power from PDA
GPS mouse - wire problem, harder to setup
Rgds
keith
