Pocket GPS World :: View topic - 6010+A6017/T2 freezes COM2 port (Toshiba E350)
kgeb2001
PostPosted: Sat Mar 12, 2005 10:10 pm    Post subject: 6010+A6017/T2 freezes COM2 port (Toshiba E350) Reply with quote
I've just bought Rikaline 6010, Rikaline cable A6017/T2 to my E350 Toshiba with PPC 2003. According to the instruction I instlled USBSER driver provided on Rikaline CD (it is required in case of Toshiba because it has USB host insead of Serial port). The problem is that GPS connection starts only for a few seconds and then freezes. I tried different software, including simple GPS viewers. Holux GPS viewer for example shows NMEA incoming strings and current time and position. But after few seconds the connection freezes. The only solution then is to soft reset my Toshiba, disconnect cable, switch off GPS and connect it again. USB Host in Toshiba works correctly - I have no problem (using USB cable) to synchronize with a PC and charging works fine as well. Is this A6017T2 (E330/E740) cable applicable for E350?
Please help !!!
