Pocket GPS World :: View topic - mounts
mounts
dhdm
PostPosted: Mon Sep 13, 2004 10:02 am    Post subject: mounts Reply with quote
Ive had my original PDA mount which was supplied with a bundle from Holux for about 12 months now, and its getting a bit tired. rattles a bit etc.
I want to fit a better one to mount my HP2210 via the windscreen.
Can anyone recommend a straight forward robust, non rattle unit??
PaperRustler
PostPosted: Mon Sep 13, 2004 10:18 am    Post subject: Ref Mounts for PDA. Reply with quote
If its any help I originally bought a cheap vent mount, which was both impractical and expensive, I eventually bit the bullet and purchased the TOM TOM windscreen mount this has the facility to charge the PDA as well as a power out to a GPS receiver.
Hope above helps.
oddsock
PostPosted: Mon Sep 13, 2004 12:54 pm    Post subject: Reply with quote
You won't get any rattling with the TomTom car kit that's for sure Smile If anything the cradle grips the ipaq too tight (2210) Iv'e managed to make mine less tight with the aid of some wet and dry paper apart from that it's excellent!!
dave
dhdm
PostPosted: Wed Sep 15, 2004 3:09 pm    Post subject: Reply with quote
Where can I get one of those mounts from? any reference number or anything as there seem to be loads advertised on here!!
Regards
Robin2
PostPosted: Wed Sep 15, 2004 4:19 pm    Post subject: Reply with quote
I bought a Brodit mount for the iPAQ2210, the type which feeds power and GPS signal through the mount. The iPAQ then slots snugly into the mount - I figured this was less likely to damage the rather flimsy Com1 contacts on the PDA.
The Brodit mount has standard slots on the back. I clip it onto a vent mount (Handnav universal fitting - fine, but Brodit make much more solid car-specific ones) in my own car. When using the sat nav in any other car (eg hire car on holiday) I slot the Brodit onto the bendy windscreen mount which I originally got with my Holux bundle.
Robin
semrots
PostPosted: Thu Sep 16, 2004 8:35 pm    Post subject: Reply with quote
Robin,
I'm looking at getting a Brodit - where did you source it from as dealers seem few and far between?
Rod
icsys
PostPosted: Thu Sep 16, 2004 9:09 pm    Post subject: Reply with quote
Click on the Handnav link over on the right...
They are the UK distributors.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
oddsock
PostPosted: Thu Sep 16, 2004 9:57 pm    Post subject: Reply with quote
The mount I have is part of the tomtom car kit and is specifically for the Ipaq 22xx with a jack for a RJ11 wired mouse ( not used if you have BT GPS unless you have the skill to adapt to charge the BT) .. the part no on the box is 6A00.015 and can be ordered direct from tomtom . Pc world part no is 537534@ £49.99 .You may find it cheaper from one of the links on these boards!!
dave
Talkingbollox
PostPosted: Thu Sep 16, 2004 10:13 pm    Post subject: Reply with quote
I bought a brodit mount from handnav.co.uk - they're one of the sponsors the right panel.
Robin2
PostPosted: Thu Sep 16, 2004 11:12 pm    Post subject: Reply with quote
Yes, I bought mine from Handnav. A lot of people had complained about delays, but they are not Handnav's fault, a lot of the mounts are car specific and have to be ordered from the makers - that can take up to 2 weeks. But I telephoned first to make sure the one I wanted was in stock, and received it the following day
Robin
semrots
PostPosted: Fri Sep 17, 2004 9:06 pm    Post subject: Reply with quote
Thanks, Handnav will get the call.
Rod
22.055 (29 May 24)
