pasgal Occasional Visitor
Posted: Sun Apr 03, 2005 5:03 pm Post subject: |
Dear friends I have tried also in hill and in opened campaign, the nemerix e' always with red light on.
pasgal |
dununda Occasional Visitor
Posted: Mon Apr 04, 2005 8:38 pm Post subject: |
pasgal, Red light is supposed to be on. Red light indictes it has a fix as far as I know. Perhaps you have not paired the device correctly with whatever BT device you have. You should have a rapidly flashing Blue light to indicate pairing.
Where are you in Italy? I Just used my BT77 to drive from Geneva to Lago Maggiore in Italy and it worked fine. _________________ BT77 GPS
Palm T3
Navman SmartST v3.0 |
Posted: Mon Apr 04, 2005 8:43 pm Post subject: |
Can anyone give me an idea if leaving the BT77 on and connected to my new Citroens Berlingos 12v power supply overnight is likely to drain the battery signifigantly? The auxilary 12v outlets in my Berlingo are always powered even with the ignition off and because of their location in the overhead lockers it is a pain to unplug them. So I thought I would just leave the plug in and the BT77 on all the time and charging overnight.
My gut feeling is the current drain would be low and would take a few days to drain the car battery. Anyone got any thoughts on this. _________________ BT77 GPS
Palm T3
ianrickycarmichael Occasional Visitor
Posted: Fri Apr 08, 2005 7:05 pm Post subject: |
i am having the same problem as brandi. have paired a bt 77 with nokia 7610 succesfully and am using tom tom mobile software. tom tom is saying its waiting for a valid gps signal and gps device is displaying a steady flashing red light on left and a steady flashing blue light on right -every 3 secs.could it be sonmething to do with installing the drivers to the phone incorrectly or is it something else-help please. |
Posted: Fri Apr 08, 2005 7:36 pm Post subject: |
it does not receive marks them satellite, one possible solution: to start the nemerix and to put it over the external roof of an automobile until when the led red it flashes 1 every 3 second ones
ianrickycarmichael wrote: | a steady flashing blue light on right -every 3 secs |
not communicate with nokia
excuse my terrible English
pasgal |
Jenno Occasional Visitor
Posted: Fri Apr 08, 2005 9:42 pm Post subject: Is this the same |
I think I have the same product differently branded - bought from PDAMODS for £60. Is this the same ???
If so where can I get som einstructions - I didn't get any with the unti (except very basic) and I'm struggling to get it to do anything. |
Posted: Fri Apr 08, 2005 11:20 pm Post subject: Re: Is this the same |
Jenno wrote: | I think I have the same product differently branded - bought from PDAMODS for £60. Is this the same ???
www.diamondpoint.co.uk/ manuals/gps/quatech/GPSR-001B.pdf
by my friend
pasgal |
Posted: Fri Apr 08, 2005 11:21 pm Post subject: Re: Is this the same |
www.diamondpoint.co.uk/manuals/gps/quatech/GPSR-001B.pdf
by my friend
pasgal |
Posted: Sat Apr 09, 2005 12:27 pm Post subject: |
Thanks Pasgal - now if it would only get a sattelite lock I'd be in business )oh and TT3 would stop crashing |
flyjedi Occasional Visitor
Posted: Sun Apr 10, 2005 12:56 am Post subject: |
i've just got one of these bt77 bluetooth jobbies, and i'm trying to get it working with tomtom3 on my ipaq hx4700. i bought it to replace the cabled one i had.
so far i've had no luck getting it working.
i've paired the device, and in the bluetooth manager there is now a shirtcut to "BT GPS: SPP slave", which I can connect to throught he manager. i went to the gps control panel for tomtom, but i can't work out the settings (or something else is messed up) because it never shows any activity (on the status tab).
what settings should i select in the GPS tab? |
iancjc Frequent Visitor
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
Posted: Sun Apr 10, 2005 6:27 pm Post subject: |
dununda wrote: | Can anyone give me an idea if leaving the BT77 on and connected to my new Citroens Berlingos 12v power supply overnight is likely to drain the battery signifigantly? The auxilary 12v outlets in my Berlingo are always powered even with the ignition off and because of their location in the overhead lockers it is a pain to unplug them. So I thought I would just leave the plug in and the BT77 on all the time and charging overnight. My gut feeling is the current drain would be low and would take a few days to drain the car battery. Anyone got any thoughts on this. |
I leave mine permanently powered via the rear power sockets (I forget to power it off most of the time) of my citroen c8 - no sign of the battery running down over a period of 4 days. As the little battery it comes with lasts 16 hours I guess the power drain is very low.
Previously I left a haicom bt unit plugged in for 5 months (removed the internal battery) - and had no problems at all. I use my car every day and drive 500 miles+ a week so the battery is always topped up - which may help.
I wouldn't leave anything plugged in if the car is being left for a period just common sense I guess.
Ian _________________ -----------------------------------------------------------
TyTn II (WM6.1) / tomtom one v2
TTN6.03 tomtom 7.xx (one) |
Posted: Sun Apr 10, 2005 6:29 pm Post subject: |
flyjedi wrote: | i've just got one of these bt77 bluetooth jobbies, and i'm trying to get it working with tomtom3 on my ipaq hx4700. i bought it to replace the cabled one i had.
try both the bt com (you want the incoming one) ports in the COM box and I use nmea v2 9600 in the gps type box.
Posted: Sun Apr 10, 2005 10:34 pm Post subject: |
sorted. ionce i upgraded to the latest version of tomtom, it gave me an outgoing com port (com8) to choose. i use tomtom wireless gps with that and it works fine. pciks up a load faster than the standard tomtom wired one i was using as well |
Posted: Sun Apr 10, 2005 11:18 pm Post subject: help please |
i have a nokia 7610(same system as 6600) and version 4.400 of tom tom mobile the driver is v 1.20 and my gps receiver is a bt77.Phone is not receiving a valid gps signal but is paired with bt77 gps .gps unit sems fine -red light flashing on left and blue flashing on right every 3 secs.Can anyone suggest where ive gone wrong-could i have the wrong drivers and can i get them from anywhere.thanx for your help. |
chime Occasional Visitor
Posted: Mon Apr 11, 2005 11:17 am Post subject: |
I've noticed that my unit is very bad at getting satellites when battery is low. (i.e. when there is only 1-2 hours left before the unit turns itself off).
In this state, it seems to do better if no devices are connected. Connecting devices seems to throw the thing off the scent.
Anyone else noticed similar problems?
Chime. |
