Pocket GPS World :: View topic - What to replace a TT BT cradle GPS with ...
ABeeBeeSee
PostPosted: Tue Mar 22, 2005 10:19 pm    Post subject: What to replace a TT BT cradle GPS with ... Reply with quote
My TomTom cradle BT GPS finally died this weekend, and is well out of warranty. Need to replace it with an equivalent unit that is powered by the car's ignition system (it has to live on the back parcel shelf, so cabled versions are no good, and don't fancy leaning over to switch it on every time ). Anyone have advice?
PostPosted: Tue Mar 22, 2005 10:57 pm    Post subject: Reply with quote
TomTom's BT GPS is one of only two I know of that allow hard wiring, the other being the Deluo BlackBox.
The obvious solution would be another TomTom Bluetooth GPS assuming the cradle still works as this is no longer supplied.
a4ace
PostPosted: Thu Mar 24, 2005 1:00 pm    Post subject: Reply with quote
what died? the cradle or the gps receiver? if the cradle, too bad if it can't be fixed. i suggest that you contact tomtom and see if they can repair it. if the gps receiver, i believe you can get a replacement bt gps receiver from tomtom.
http://www.tomtom.com/products/accessory.php?ID=56&Product=1&Category=&Context=1&Language=1
tomtom 940 live/tt active dock holder/tt rds-tmc traffic receiver usb
MrT
PostPosted: Thu Mar 24, 2005 1:59 pm    Post subject: Reply with quote
The cradle has a single IC regulator chip in it that is available from any electronics shop such as Maplin. If you are not into soldering, find a friend who can, it is a simply job for anyone with moderate soldering skills.
The particular chips are usually reliable so recheck your wiring first. The pins in the hard wired cable can slip out the end plug.
ABeeBeeSee
PostPosted: Thu Mar 24, 2005 10:36 pm    Post subject: Reply with quote
Thanks everyone.
I'm sure it's the GPS unit itself - symptom is short flash of blue BT LED when switched on, followed by constant green GPS signal LED, then can't be switched off. Left it for over a week on discharge - no sign of useful life from it when recharged - via the cradle or direct. Similar symptoms to other messages in this forum saying GPS is dead.
How do I check if cradle is faulty?
a4ace
PostPosted: Sun Mar 27, 2005 1:52 pm    Post subject: Reply with quote
i don't think you can check the cradle without a working gps receiver. so either you get a replacement bt gps from tomtom, or get the deluo. the only problem with the deluo is that you can't take it outside of the car if you want to use tomtom for walking. the replacement bt gps could also be prone to the same problem over time.
22.055 (29 May 24)
