jeffblockley Occasional Visitor
Posted: Sun Mar 06, 2005 11:37 pm Post subject: Can i change the data.chk file back |
I have changed my data.chk file will all the sounds be on my cameras now or do i drag and drop the wave files into my GB folder as i see that some of the sounds are different from the sounds that i downloaded from the data.chk file.
Is it possible to get the original data.chk sounds back once you have changed them. Also can i leave my old camera files on my card aswell as the new ones.
Jeff |
Oldboy Pocket GPS Moderator
Posted: Mon Mar 07, 2005 7:16 am Post subject: |
1. TTG can't play .WAV files so there would be no point in copying them over.
2. If you didn't delete your old data.chk file you can copy the original file over the new. If you deleted it, and you previously copied your whole SD card to the PC, you could copy it from there.
3. The Zoned cameras are duplicates of the old cameras, just organised into a seperate speed ratings. If you keep both, the map might get rather cluttered and the number of POI's might exceed the limit of 40. _________________ Richard
Posted: Mon Mar 07, 2005 12:18 pm Post subject: |
I did copy my SD card to my PC but i don't see the data.chk file on my copy but i see it on my SD card i have changed it over to the new sounds OK but i was just looking to find out if i could change it back to it's original state.
Jeff |
Posted: Mon Mar 07, 2005 12:32 pm Post subject: |
I have now tried to restore my setting on my SD card from my PC but after i do that i do not get the old sounds back.
Jeff |
MrPloppy Occasional Visitor
![](modules/Forums/images/avatars/gallery/simpsons2.jpg)
Posted: Mon Mar 07, 2005 2:26 pm Post subject: |
Oldboy wrote: | <snip>
3. The Zoned cameras are duplicates of the old cameras, just organised into a seperate speed ratings. If you keep both, the map might get rather cluttered and the number of POI's might exceed the limit of 40. |
I didn't know this! That's why I get "GATSO 30... GATSO" coming up - there are two waypoints on the same spot. So I can safely delete which POIs? |
Posted: Mon Mar 07, 2005 6:52 pm Post subject: |
jeffblockley wrote: | Richard
Jeff |
Did you copy from SD to PC after you changed to the new sounds?
If yes you will have to re-install TTG! Are you still using the 128MB card or have you upgraded? If you have upgraded, and you haven't wiped the 128 card clean, the Data.chk file will be on there. Just swap cards back copy data.chk to PC, put new SD in again, and copy from PC to new SD.
Rememeber to switch off TTG when changing cards. _________________ Richard
Posted: Mon Mar 07, 2005 6:56 pm Post subject: |
MrPloppy wrote: |
Either the main, large, Gatso file or all of the speed marked files, including the TBA file. It depends how many POI's you want (need) now or in the future as there is a limit. _________________ Richard
Posted: Mon Mar 07, 2005 7:06 pm Post subject: |
Hi Richard
I made a copy to my PC before I changed the data.chk file. I am still using my 128MB card I took all the voices that i don't use off my card.
Jeff |
Posted: Mon Mar 07, 2005 7:15 pm Post subject: |
I got it the file is on the CD thanks for your help.
Jeff |
Posted: Mon Mar 07, 2005 8:05 pm Post subject: |
Jeff |
Be careful. You can't just copy the file from the CD, it's compressed. Only TTG setup can decompress it! _________________ Richard
Posted: Mon Mar 07, 2005 11:04 pm Post subject: |
I just right clicked and sent the file to my SD card i had plugged into my PC and that worked OK.
Jeff |
Posted: Tue Mar 08, 2005 7:00 am Post subject: |
I didn't think it would, but I'm glad it did. ':D'
Don't forget to safe a copy of your SD card, just in case!! _________________ Richard
