craigaucott Occasional Visitor
Posted: Tue Mar 01, 2005 10:46 am Post subject: Can I be guided to a co-ordinate rather than an address ???? |
Is it possible to set a co-ordinate as your destination in SmartST ??? (eg. N 51° 18.121 E 000° 34.366)
I can only see options for addresses or POI's.
The other option would be to set a POI at that co-ordinate, but can you do this ???
I have only had the software since yesterday, and have not found out a way to do it yet. |
uffe73 Frequent Visitor
Posted: Tue Mar 01, 2005 11:02 am Post subject: Re: Can I be guided to a co-ordinate rather than an address |
craigaucott wrote: | Is it possible to set a co-ordinate as your destination in SmartST ??? (eg. N 51° 18.121 E 000° 34.366)
No, you cannot get routing to a long/lat position in SmartST. Hopefully this feature will appear in V4! _________________ TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70) |
Posted: Tue Mar 01, 2005 11:05 am Post subject: |
OK.
Thanks Uffe.
I'll have to see if any other software will do it. |
Posted: Tue Mar 01, 2005 11:31 am Post subject: Re: Can I be guided to a co-ordinate rather than an address |
As Ulf says, you can't (yet) route to a set of coordinates , nor can you create a POI at a set of coordinates on the device. However, if you have the time, you can create POIs on the Desktop software using the POIEditor and then transfer them to the device. On the PPC version then you have to have the device connected to be able to use the POIEditor, though. I assume, but don't know definitely if, the iCN series are the same. _________________ Tim |
kartracer Frequent Visitor
Joined: 26/03/2003 20:15:33 Posts: 502 Location: United Kingdom
Posted: Tue Mar 01, 2005 12:09 pm Post subject: |
Another option, if you have a registry editor, is to create a favourite... it doesn't matter where. You can then edit the registry key containing the Latitude and Longitude for that favourite.
e.g.
HKEY_LOCAL_MACHINE\SOFTWARE\Navman\Smartst Pro\Favourites\Items\Keyed\KFAVNAME\Latlong
where FAVNAME is whatever you called your favourite. _________________ Kam |
Posted: Tue Mar 01, 2005 5:14 pm Post subject: |
If I did that, what would SmartST do once I got off-road ???
Will it tell me the direction I need to travel, or will it try to send me back to the nearest "acceptable" road ???
Would it give me a pointer, or say "Continue for XX metres in *This* direction" ??? |
Posted: Tue Mar 01, 2005 5:28 pm Post subject: |
craigaucott wrote: | If I did that, what would SmartST do once I got off-road ??? |
It won't take you off-road. If it thinks you are off-road it will just tell you to drive to the nearest road. _________________ Kam |
Stefan Occasional Visitor
Posted: Tue Mar 01, 2005 10:19 pm Post subject: |
It sounds like you might want to consider a different GPS package. For 'off road' and co-ordinates have you considered Memory Map?
Stefan |
BBB Regular Visitor
Posted: Wed Mar 02, 2005 5:51 pm Post subject: |
Can Memory Map do both?
Does it have a timeloaded demo? |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Wed Mar 02, 2005 6:44 pm Post subject: |
All the topographical software packages, which are ideal for 'off road' wether it be driving or walking, have demos.
Check out www.memory-map.co.uk www.anquet.co.uk www.fugawi.com _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
BBB Regular Visitor
Posted: Thu Mar 03, 2005 1:36 am Post subject: |
The one that is attracting my attention at the moment is a Microsoft Product Street & trips 2005
Apparently compatible with PC, PPC and smartphones
No more of this snagged in silly stupid programing
In a way I can't wait for my maps to be outdated
Groovy!
ps - streetwise I mean I don't think MS do topo (yet?) |
Posted: Thu Mar 03, 2005 8:15 pm Post subject: |
Have you seen the maps on Streets and Trips? (which is the US version by the way)
If you look at Autoroute (EU version) maps they are nowhere near as good as Navman or TomTom. And it does not provide voice guidance or any guidance for that matter. It merely plots your position on the map.
Don't get me wrong, it works and is pretty accurate but it is no substitute for a proper sat nav product. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
BBB Regular Visitor
Posted: Thu Mar 03, 2005 9:12 pm Post subject: |
I guess there had to be a catch in it
Thanks icsys |
SamOntario Occasional Visitor
Posted: Fri Mar 18, 2005 8:56 pm Post subject: |
BBB wrote: | The one that is attracting my attention at the moment is a Microsoft Product Street & trips 2005
Groovy!
Streets & Trips 2005 has advantage of very updated map data and very easy to locate the address on laptops. Problem - it has no sound as someone already indicated.
On PPC, when exporting maps to PPC, each map is limited to below 5 MB, i.e. within 30 minutes drive, you need to change maps and there is no way you can merge the maps. Its only good when you are in that city. |
Posted: Fri Mar 18, 2005 9:01 pm Post subject: |
Forgot to mention, for PPC, there are already main city maps around the world for free download. |
