AndyMac Occasional Visitor
Posted: Sun Feb 27, 2005 4:13 pm Post subject: TomTom 3 dongle problem!!! |
Hello all, I have a problem with my dongle! 8O
By which I mean the grey square thingy that comes with a wired tomtom 3 PDA kit. I use this kit with the Tomtom car mount and a HP 2210.
The connector between the dongle's wire and the window mount is loose. The black protective moulded covering on the RJ45? connector has moved down the cable which allows the cable inside to rotate and move about a bit in use, this exact problem caused the death of my last dongle (Which was replaced under warranty) I don't want to have to go through that hassle again , is there any fix for a dodgy dongle?
Any thoughts happily accepted!!!
Andy |
Googlebot Regular Visitor
Posted: Sun Feb 27, 2005 11:32 pm Post subject: |
The so called 'Dongle' is actualy your GPS reciever. TomTom is not dongled hardware/software.
Cant help with the wires though, but atleast other will hopefuly now be able to help... _________________ iPAQ 2110
Kingston 512Mb SD card
Kingston 1gb CF card
Holux CR-100
Soon to be replaced with TT720 (maybe....) |
StevenGourlay Frequent Visitor
Posted: Mon Feb 28, 2005 4:55 pm Post subject: |
You could probably fix this easily if your remove the shell of the car kit (but by doing that you invalidate the warranty) I would recommend that you call tomtom to get it repaired. _________________ Regards
Steven Gourlay
Bike Pics! Bike Chat! Visit-Ullapool |
oddsock Pocket GPS Verifier
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Mon Feb 28, 2005 7:17 pm Post subject: Re: TomTom 3 dongle problem!!! |
AndyMac wrote: | Hello all, I have a problem with my dongle! 8O
Andy |
I had the same problem ..I fixed mine by sliding the cover down the cable and removed the old glue ..then I slid it back to the correct position over the connector then inserting a jewellers screw driver between the cover and the cable and gently levered a small gap and squirted a drop of instant glue in there and whipped out the driver .. then repeated the operation at 180 degrees ..Its been OK for a few months now!!
Dave |
