Pocket GPS World :: View topic - Memory Cards
Memory Cards
hasoodh1
PostPosted: Mon Jan 10, 2005 10:53 pm    Post subject: Memory Cards Reply with quote
I bought a PNY SD 1GB Card for my TTG, the problem is the fitting is a bit tight when it goes in and when trying to take its a struggle as it doesn't spring out. I had to use my finger nails but got it out in the end, tried it a few times to ease it off, it did ease off a little but still stiff. I am going to return it back to the supplier as this is not acceptle behaviour. The card did work fine when connected to PC and when out and about but I do not want to damage my TTG as this is worth a lot more than the card. Would this damage the TTG memory card slot? Mine seems ok anyway
So can anyone recomend a good quality card I could use?
Many Thanks
Hoss
lbendlin
PostPosted: Tue Jan 11, 2005 3:11 am    Post subject: Reply with quote
Lexar seems to be fine
Lutz
TomTom/TeleAtlas NAVTEQ
Frazzle
PostPosted: Tue Jan 11, 2005 1:45 pm    Post subject: sticking SD card Reply with quote
I had the same problem with my Viking SD cards.
It turned out to be the sticky label Viking had applied to the card to cover up the cards true identity - TOSHIBA !
The label extended the full length of the crad instead of just the recessed bit at the rear. The thickness was increased enough by the label to make the card stick in the SD card slot.
Removed the label and all is well now :-)
g0sbv
PostPosted: Tue Jan 11, 2005 2:15 pm    Post subject: Reply with quote
Kingston
22.062 (12 Jun 24)
