Pocket GPS World :: View topic - Reception in Clio 172
BanziBarn
PostPosted: Thu Dec 16, 2004 10:54 am    Post subject: Reception in Clio 172 Reply with quote
My mate has just bought a GO and is getting virtually not signal in his Clio, but he gets full signal in his GFs Astra (unit therfore OK). I'm guessing then that the clio has some kind of heated windscreen whch is obstructing the signal.
But I would be just interested to know if anyone has got good reception in a Clio and if so, where it was possitioned etc..
Cheers guys Smile
jdatkinson
PostPosted: Thu Dec 16, 2004 2:38 pm    Post subject: Reply with quote
Renault / Peugeot / Citroen cars typically have athermic / heat reflecting windscreens fitted which block GPS reception most effectively. The definitive solution is an external aerial. A quick browse around the forum area will reveal that the offical TomTom antenna is in very short supply.
Encantador
PostPosted: Thu Dec 16, 2004 11:23 pm    Post subject: Had the same problem in a ..... Reply with quote
Vauxhall Zafira, didn`t really want to have to use external receiver found the Go fits neatly on the drivers door window and works OK.
PostPosted: Fri Dec 17, 2004 10:30 pm    Post subject: Reply with quote
Athermic windscreens are fitted to most french manufactured cars.
BanziBarn
PostPosted: Sat Dec 18, 2004 12:21 am    Post subject: Reply with quote
OK, thanks for the replies guys Smile
Sculli
PostPosted: Sun Dec 19, 2004 11:08 pm    Post subject: Reply with quote
I too have an '04 Clio and found myself needing the external antenna. No need to trail the wire round the car though as there is an uncoated area of windscreen at the bottom - the receiver just needs to sit below this and it works fine.
This make it far far easier to take the mount out of the car. I am considering shortening the cable so that there is only 4" of wire between the mount and the receiver as this is all it needs - just a little worried about killing the whole thing!
