breers Occasional Visitor
Posted: Fri Nov 19, 2004 10:36 pm Post subject: SPEED CAMERS DOWNLOAD |
i am getting the message 'no POIs in the input file' when trying to download the speed camera database? this is just about the last instruction to follow and i am falling down at this hurdle. can anyone advise please. also i am running a 128 meg sd card with uk maps pre-installed - will i have enough space?
steven |
Posted: Sat Nov 20, 2004 12:21 am Post subject: |
I honestly don't know as to whether or not you have enough memory available, but you should be warned on transfer if you haven't. Regarding actually installing the database, have you fully followed the revised instructions here? _________________ Tim |
Posted: Sat Nov 20, 2004 12:36 pm Post subject: |
thank you tim - i have actually read through the instructons you signposted me to, all is well until i reach stage 7 'enter name for POI file' - its at this point (after a little pause) that I receive the message ' no POIs in the input file??? - i dont receive the transfer message either, i assume its due to the above problem - so frustrating as i really would like to download this feature. when trying to download, i have my navman hooked on to my pc via the usb cable and all is turned on, is this the right procedure? advice by all most welcome.
steven |
Dave Frequent Visitor
Posted: Sun Nov 21, 2004 6:43 pm Post subject: |
Which file did you try to import, and was it the XLS or CSV file ? |
Posted: Sun Nov 21, 2004 8:40 pm Post subject: |
pocketgps_uk_gatso.csv
this actually opens via excel, and i have deleted the line as instructed - it is identical to what is displayed on the download database - help most welcome dave
steven (breers) |
Posted: Mon Nov 22, 2004 9:49 am Post subject: |
...and let me guess, you've then re-saved it in Excel ?
As per the instructions, you need to do this in Notepad, otherwise it will change the file format if your not careful and will create the problems you are experiencing when importing it. |
Posted: Mon Nov 22, 2004 10:54 pm Post subject: |
thank you so much dave - this put me on thr right track and i feel sure i have downloaded correctly. the download told me what memory i had avaialbe and i subsequently downloaded. it told me to check my navman software to make sure, i did, it is now sitting on my 128 meg card in my 'my pois' - which i ticked for what i am sure was to activate - will try out tomorrow. by the way great site. i'm hooked'
steven - breers |
