AlexM Occasional Visitor
Posted: Tue Oct 26, 2004 5:18 pm Post subject: help |
hi,
i have followed your fantastic instructions but when i send to unit i get an error:
"names and places have exceeded the 16mb limit"
and it does not send...
Any ideas |
Dave_L Occasional Visitor
Posted: Wed Oct 27, 2004 10:15 am Post subject: |
AlexM,
I had the same error message
Did it take a while for POI editor to come up with the message ?
Did you delete the final empty quotes column that POI converter produces ? (I read somewhere that you must delete this column, so that's what I did initially and got that error message).
When I tried again and left the column in, the POI editor was happy and reported the available and required memory correctly, allowing the transfer to succeed. |
icsys Frequent Visitor
Joined: Feb 20, 2004 Posts: 1154 Location: South Lancashire, UK
Posted: Wed Oct 27, 2004 7:23 pm Post subject: |
By following the instructions exactly as posted you should not have any problems.
But if you do, simply post here and we will endeavour to help where we can. _________________ Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
Simon1 Frequent Visitor
Posted: Sat Oct 30, 2004 1:30 pm Post subject: |
Quick question: now the new speed camera database is out, if I name the files the same as the ones I already have on my 510, will they simply install over the top of the old ones when I send them to the device or do I need to remove the old ones first? |
Posted: Sat Oct 30, 2004 1:31 pm Post subject: |
You could always try it! But seriously, the existing files will be overwritten, although I always delete the existing ones first. _________________ Tim |
mpuk Occasional Visitor
Posted: Sun Oct 31, 2004 8:50 pm Post subject: "16MB limit" error |
Hi there
I have also tried to load the Gatso database onto my iCN 510 and have encountered the same 16MB limit error message.
I have followed the instructions to the letter 3 times and with no luck.
Any ideas?
Thanks |
Dave Frequent Visitor
Posted: Sat Nov 06, 2004 4:10 pm Post subject: |
NOTE - Instructions are now obsolete since October Release - Please see these instructions. |
tongtong Occasional Visitor
Posted: Sun Nov 07, 2004 8:02 pm Post subject: |
i followed the directions given to upload the poi s. only thing different was that the lat long file i was not able to extract was mailed to me by you (icsys) in excel format. the rest was easy. every thing went all right. but i did not get any warnings from the navman on the roads when there were cameras i know for sure.
any ideas? |
Posted: Sun Nov 07, 2004 9:25 pm Post subject: |
You need to set the cameras up in Active POI's
Main Menu | Settings | Alerts | then the Active POI tab.
Make sure the safety camera database is shown, check the Active box, also check Visual warning and Sound Warning boxes.
You can also set the distance before the POI to be alerted.
Once you have done this you will get the warnings. _________________ Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Posted: Wed Nov 10, 2004 12:08 am Post subject: |
icsys wrote: | You need to set the cameras up in Active POI's
Once you have done this you will get the warnings. |
all this was already done. i checked it again. but no speed camera warnings. yet, |
