Pocket GPS World :: View topic - External battery pack for clip on
topgazza
PostPosted: Tue Oct 26, 2004 1:08 pm    Post subject: External battery pack for clip on Reply with quote
Does such a beast exist?
PostPosted: Wed Oct 27, 2004 8:57 am    Post subject: Reply with quote
Sure, in theory there's no reason why you couldn't say use the 4xAA battery pack extender that PC-Mobile sells. This charges the PDA and gives you around 3 full charges, It's quite a lot larger than a Clip-On but if you don't mind having it plugged in say in-car that way, or when you're walking with it then it'll work well.
I now have three of these baby's and they really do come in handy as a life saver!
http://www.pocketgpsworld.com/pcmobile-battery.php
topgazza
PostPosted: Wed Oct 27, 2004 11:15 am    Post subject: Reply with quote
Looks good for my iPaq, very good. But I was more concerned over the Fortuna Clip On which would have a different connector of course.
PostPosted: Thu Oct 28, 2004 1:27 pm    Post subject: Reply with quote
Not if you buy the 3600 battery pack, it will come with a normal jack plug and I've tested mine and it does fit the Fortuna Clip-On socket and charges the Clip-On (although I haven't done an extended charge).
You may want to check the voltage/amps of the Fortuna Clip-On charger (can't locate mine at the moment).
TC
PostPosted: Thu Oct 28, 2004 9:15 pm    Post subject: Reply with quote
You can also buy a battery extender with a female USB connector it and therefore use the Fortuna USB cable. If you buy one of those nice retractable USB/Ipaq leads you can also plug this into you battery extender. ie one battery extender charges both Ipaq and Clip-on
Try Shirtpocket.co.uk for the extender...
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
