Pocket GPS World :: View topic - Backing Up Everything
moggy
PostPosted: Fri Oct 15, 2004 7:00 pm    Post subject: Backing Up Everything Reply with quote
what is the best way to go about doing a full backup on the ppc?
including main memory and registery. the whole lot and everything that is on a CF card.
basically, if my ppc goes down on the road and i need to perform a hard reset i want to be able to load everything back in and still run navigator.
so if my CF card went down, i could insert my SD card and run it from there.
i've tried to copy and paste everything from my CF card onto my SD card but when i took out the CF card and inserted the SD card, it wouldn't find navigator. might have something to do with the dll's pointing to the CF card where it was all origianlly installed to? i don't know.
it certainly wouldn't run though.
is there a program to do all this or has it all got to be done manually and what is the correct procedure to go about this.
PostPosted: Fri Oct 15, 2004 9:16 pm    Post subject: Reply with quote
you cannot replace the CF card with the SD card because the physical paths are different.
Depending on your Pocket PC you may already have a built in backup program. You can use that or you can purchase one - like Sprite Backup
22.055 (29 May 24)
