Pocket GPS World :: View topic - My Garmin died on me
g0tch
PostPosted: Wed Jun 06, 2018 5:03 pm    Post subject: My Garmin died on me Reply with quote
Seen post of map update today so thought I look to see if I can update. Sorry to say, my Drivesmart dosen't show any life by pressong the power button or by connecting power supply or laptop.
Is there anything I can try please?
Tibor
Garmin Drivesmart 61
PostPosted: Wed Jun 06, 2018 6:28 pm    Post subject: Reply with quote
Yes. Just leave it connected as the battery is possibly very flat.
Dabri
PostPosted: Wed Jun 06, 2018 6:32 pm    Post subject: Reply with quote
If it is the same problem that occasionally afflicts my 3598 after updating maps, POIs or speed cameras, then press and hold the on button until the unit tries to start, then release - only about 5 seconds. Repeat as necessary - on my unit this can generally be up to 20 attempts. It this is not the same problem as yours, then sorry I can't help. If something does eventually work for you, please let us know how you did it.
Dabri.
Navman iCN530T; Garmin 760T v4.80; Garmin 765T v4.00; Garmin 2460LMT v3.60; Samsung S3;
Garmin 3598LMT-D v5.50; Samsung J6; Garmin DriveSmart76 LT-D v6.80; Samsung A52.
g0tch
PostPosted: Wed Jun 06, 2018 6:48 pm    Post subject: Reply with quote
Many thanks guys. Panic over. After 3 hrs plugged in, it came to life. Not sure why the battery got so flat though. It is now updating to latest map. At least I won't panic so much if it happens again.
Best regards,
PS. I long pressed the power button till it asked me if I want to turn off. Didn't realize it was the correct way to do it Very Happy .
Tibor
PostPosted: Wed Jun 06, 2018 8:41 pm    Post subject: Reply with quote
Very Happy
PostPosted: Sat Sep 01, 2018 9:32 am    Post subject: Reply with quote
Just spotted this post.
My 2699 is the same after a map update but the 2599 is OK. Must find the charge lead.
Now up to 10% after half an hour.
Satnav:
Car Average MPG :
illestko
PostPosted: Sun Oct 07, 2018 4:59 am    Post subject: Replace the battery Reply with quote
Super easy to replace the battery on these devices. Also replacement batteries go for like $10 on eBay etc.
Just youtube some videos and grab an old credit card and small screw driver and you're set. Ive seen some battery replacements come with cheap one time use tools.
Goodluck!
illestko
PostPosted: Sun Oct 07, 2018 5:01 am    Post subject: Reply with quote
Pretty common on garmins with daily use. The connector gets weak and can only hold a charge when you have the cable tugging in a specific orientation.
You could theoretically put it into an oven once disassembled to let the solder reflow into the connectors.
Just make sure the battery and LCD are all removed and its just the board going into the oven.
PostPosted: Sun Oct 07, 2018 6:32 am    Post subject: Reply with quote
I've read about this connector problem but I reckon that's down to mishandling. Falling off the screen and being saved by the cable possibly.
I've had quite a few Garmins plugged unplugged twice daily and never had an issue.
Satnav:
Car Average MPG :
PostPosted: Sun Oct 07, 2018 7:20 am    Post subject: Reply with quote
Yep, me too over the years, never been an issue Smile
