daxara Occasional Visitor
Posted: Thu Apr 27, 2017 3:58 pm Post subject: Garmin 2589 Help please |
I have a few problem's I would like to sort out with my 2589 with your help....first I have updated to the latest map and it seem's to have some speed driving faults IE it tells me I am in a 30 mph zone when it is 60 mph.
2nd I have a back up of the previous map etc on my computer which worked fine so can I restore those,if so how please.
3rd can I get rid of the annoying beeps/chimes and the red speed zone warning allerts off the unit which appear everytime you enter such zones I don't need them as I will rely on the speed camera's I down loaded from here with the audio warnings.
If you can help with these I would appreciate it.
Thanks |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Thu Apr 27, 2017 4:09 pm Post subject: |
Best solution if the map speed limit is wrong is to report it as an error to Garmin.
Not sure which beeps/chimes you're getting. If they're from the pre-installed Garmin ones and you no longer intend to use them just delete the relevant .gpi files in the POI folder on your device. _________________ Where there's a will ... there's a way. |
M8TJT The Other Tired Old Man
Posted: Thu Apr 27, 2017 4:29 pm Post subject: Re: Garmin 2589 Help please |
daxara wrote: | it seem's to have some speed driving faults IE it tells me I am in a 30 mph zone when it is 60 mph. | This is a mapping error, so as suss says, report it (but whether anything eill be done about it......) Quote: | 2nd I have a back up of the previous map etc on my computer which worked fine so can I restore those,if so how please. | Pass Quote: | can I get rid of the annoying beeps/chimes and the red speed zone warning allerts | Settings ~ Map and Vehicle ~ Audible Speed Alerts (untick) |
Posted: Thu Apr 27, 2017 5:02 pm Post subject: Thanks |
Thanks for the reply's I will report the speed fault to Garmin and see if it get's sorted.
I deleted the UKIrelandCyclopsSample,gpi file from the Poi folder I hope it's the right one to remove the Speed warnings/chimes/bells which came with the unit.
You did not say how I can restore my old Map from a folder on the computer or can I not do it that way....should I just do a complete reset and try and start again as the Map I have is the faulty one on the speeds.
Cheers. |
Posted: Thu Apr 27, 2017 5:17 pm Post subject: |
Yes that's the right file. I wouldn't bother to go back to an older map just because you've found one speed limit wrong, all maps will have errors like that as no one can keep up with the changes that go on. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Thu Apr 27, 2017 6:23 pm Post subject: |
If the speed limit was right but is now wrong, and the road hasn't changed, then could this need a master reset ?
Seems odd that Garmin or the map provider would just change it without firm evidence. _________________ Satnav:
Car Average MPG :
Posted: Thu Apr 27, 2017 6:38 pm Post subject: |
daxara wrote: | I deleted the UKIrelandCyclopsSample,gpi file from the Poi folder |
sussamb wrote: | Yes that's the right file. | Surely, that's only the Garmin speed cameras. Which can be turned off without having to delete the file and does not include the road speed limit data. |
Posted: Thu Apr 27, 2017 11:38 pm Post subject: |
Agreed, but if he's not wanting to use it it's worth getting rid of the file.
I'm not sure K that a master reset would help, as it's simply reading the data for that road and displaying it. @daxara perhaps you could let us know which road so we can check it out? _________________ Where there's a will ... there's a way. |
Posted: Fri Apr 28, 2017 5:34 pm Post subject: Wrong Speed's |
The Road I was on is the A1066 coming through South Lopham towards Bressingham.
When I left the 30 mph section back into the 60 mph section I was being warned it was 30 mph which is wrong this went on for about 1.5 miles before it reverted back to the right speed limit on the screen....hope this helps
Daxara
One good thing is if I drive to the 30 warning and not the 60 mph I won't get done for speeding hi... |
Posted: Fri Apr 28, 2017 6:12 pm Post subject: |
Strange, I've just run a simulation on my DriveSmart and using that, combined with looking at Google streetview, my device is reporting the speed limit correctly.
Despite my earlier reservations it may be worth trying a master reset. _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Fri Apr 28, 2017 9:59 pm Post subject: |
Yes, same here.
I have a 2599 (near enough to yours) and the latest maps.
On my simulation, the Garmin switched from displaying a 30 limit icon to a 60 limit icon, about a third of the way between Redgrave Road (B1113) and Lopham Road (the next left).
You mention "warnings" for the 30 limit in the 60 area. Perhaps these were emitted by the Garmin Cyclops data (now removed) and so should not recur.
Dales _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Fri Apr 28, 2017 11:11 pm Post subject: |
But are there, or has there been any cameras down that neck of the woods that the Cyclops is alerting for? Are we getting road speed limits mixed up with camera alert speeds I wonder? |
Posted: Sat Apr 29, 2017 7:05 am Post subject: |
Does need clarifying. _________________ Satnav:
Car Average MPG :
trevorthomson13 Occasional Visitor
Posted: Tue Jul 18, 2017 11:16 pm Post subject: how did you get speed zone icons on your nuvi 2599lmt-d ive |
dales wrote: | Yes, same here.
Dales |
Posted: Tue Jul 18, 2017 11:20 pm Post subject: how do you put speed cam voices on nuvi 2599 lmt thanks |
sussamb wrote: | Strange, I've just run a simulation on my DriveSmart and using that, combined with looking at Google streetview, my device is reporting the speed limit correctly.
Despite my earlier reservations it may be worth trying a master reset. |
