Pocket GPS World :: View topic - Kenwood dnx8160dabs with garman
TUCSONRON
PostPosted: Tue Mar 21, 2017 9:59 pm    Post subject: Kenwood dnx8160dabs with garman Reply with quote
Just put on cameras etc.does anybody now how you switch on the voices .
it bleeps but no voices.It shows voices when you upload.
How you get into poi to see if it has uploaded.
Hope you can help.
cjay2412
PostPosted: Tue Mar 21, 2017 10:51 pm    Post subject: Reply with quote
you need to install sox.exe so poi loader can add the voices. got it working without issue on my system
PostPosted: Wed Mar 22, 2017 12:14 am    Post subject: Reply with quote
You need to put sox.exe into the same folder as the poiLoader.exe file.
TUCSONRON
PostPosted: Wed Mar 22, 2017 3:07 pm    Post subject: Reply with quote
You need to put sox.exe into the same folder as the ptoiLoader.exe file.
thank you both for your repleyl am not very good with all this could you tell me and how to do this sox.exercise
Should this have been when I extracted the speed cameras on to the memory stick.
PostPosted: Wed Mar 22, 2017 3:30 pm    Post subject: Reply with quote
1. Download a copy of sox.exe from my dropbox HERE
2. Open your Downloads folder and right click on sox.exe and chose 'Copy'.
3. Open 'My Computer' and navigate to C:\Program Files (x86)\Garmin\POI Loader.
4. In that folder you should see POILOader.exe listed.
5. Click in an empty space in the folder and 'Right click ~ Paste'
7. Run poiloader in the way that you do to get the cams on the stick.
If you are not using POILoader, what EXACTLY are you doing to get the camera alerts to work (with no voices)?
Note: If you cannot see the .exe at the end of the filename, don't wory, but more importantly, don't add it. If you want to see file extensions then in Explorer (My Computer) Click on the View tab and select (tick) 'File name extensions'. This is for W10, but it can be done differently in earlier versions of Windows.
If you have a MAC, hard luck, I can't help.
TUCSONRON
PostPosted: Wed Mar 22, 2017 9:46 pm    Post subject: Reply with quote
Thank you very much for your help.
Yes i did everything POILoader as it said.
Just followed all your instructions .
Got to stage 4 opened the folder they is no POILOader.exe listed in this folder. they are all differant for countrys but no exe in the e is POILOader.ell and POILOader.esp
Sorry is it me i really thank you for your help should i just leave it .
TUCSONRON
PostPosted: Wed Mar 22, 2017 11:19 pm    Post subject: Reply with quote
[quote="TUCSONRON"]
Sorry didn't read the notes at bottom
I think i have done it yes i ticked the box so the poiloader.exe up near the top.
went to the side clicked paste now the sox.exe file is at the bottom is that correct.
So now just loaded it all on to stick. Do i have to delete the other one on the unit or just put the stick in the usb port . Will this just override the one that is already on unit. hope this make sense.It says on the stick Garman then poi then poi.gpi opened poi.gpi shows 1462kb hope this makes sense to you will this have everything i need now.??
PostPosted: Wed Mar 22, 2017 11:45 pm    Post subject: Reply with quote
It matters not. The files are arranged in any order you want them in. By default, new files go at the bottom, but if you refresh they will then normally be in alphabetical order.
I don't know as I don't have your device.
Use the 'Reply' button at the bottom of the page instead of the 'Quote' button unless you need to quote bits to get stuff in context as I have done.
PostPosted: Thu Mar 23, 2017 8:17 am    Post subject: Reply with quote
As posted, once you have POIloader installed just plonk the SOX.EXE in the same folder.
Simples
Satnav:
Car Average MPG :
TUCSONRON
PostPosted: Fri Mar 24, 2017 7:46 pm    Post subject: Reply with quote
I have done everthing you both said, does it write over the over one thats already on the sat nav.
Or do i have to delete the first one i have put on.
i thank you both for your help.
cjay2412
PostPosted: Sat Mar 25, 2017 9:07 pm    Post subject: Reply with quote
it should over write the old data. best to keep the USB stick inserted all the time as I find the alerts stop when removed.
cliffknight
PostPosted: Tue Jan 23, 2018 11:07 pm    Post subject: Kenwood DNX8160DABS with Garmin Reply with quote
I cant even get the cameras to load when I insert the SD Card into my Kenwood DNX8160DABS (with Garmin). Followed instruction (with sox.ex in the poi folder), downloaded, unzipped, poi to SD Card, poi.gpi file in SD card, inserted SD Card into satnav .... nowt, zippo ..... I presume PocketGPSWorld does work on my device (Kenwood recommended it) .... any ideas pleeeease
dales
PostPosted: Tue Jan 23, 2018 11:25 pm    Post subject: Reply with quote
Your help is on the PGPSW database board, where you have posted the same question.
It's best to ask the same questions only in one place, just once, or the replies get muddled.
Dales.
