Pocket GPS World :: View topic - Garmin CSV to GPX Converter
Goto page Previous  1, 2, 3 ... 39, 40, 41 ... 73, 74, 75  Next
PostPosted: Tue Jan 10, 2017 3:05 pm    Post subject: Reply with quote
It is now.
I had to make the same change which involves forcing a Working Directory set upon first install.
Satnav:
Car Average MPG :
PostPosted: Tue Jan 10, 2017 3:19 pm    Post subject: Reply with quote
Well I'm still completely perplexed ...
I deleted all working folders, camera folders, downloaded files etc and started from scratch. Just downloaded and created a new file and installed it onto my satnav. The two cameras that were coming up correctly on my 2508 as 50mph still do so. The cameras that BaseCamp was previously incorrectly reporting are still being incorrectly reported, one shows up as 164704#70 and one as 172935#40 so are shown as 70 and 40mph respectively and not 50mph. Both show correctly as 50mph when you view them via the PGPSW website Twisted Evil
I cannot see how this could possibly be happening unless somehow both cameras are duplicated in the data that I've just downloaded from PGPSW, one with the incorrect speed and one with the correct one??
PostPosted: Tue Jan 10, 2017 3:22 pm    Post subject: Reply with quote
Laughing
Satnav:
Car Average MPG :
dales
PostPosted: Tue Jan 10, 2017 5:00 pm    Post subject: Reply with quote
Suss,
Those two camera numbera are not duplicated in my copy of the latest PGPSW download - I've looked.
If you open the .csv file in Excel and search for the camera numbers - they are only there once. In fact there are now no Redspeed seventies left at all.
You were right that Basecamp can read them from the device.
So now I can see on my Basecamp screen the two cameras with red Fifty icons, plus the old ones with blue flag icons labelled #40 and #70 (these being the ones I imported into Basecamp from some old gpx files).
Is it possible you've got an old .gpi file kicking around in your device or on its SD card, perhaps.
Dales.
PostPosted: Tue Jan 10, 2017 5:02 pm    Post subject: Reply with quote
Kremmen suggested that you delete the cameras off the Garmin and then see if the rogues are still there. I don't really know what he is talking about as I haven't used basecamp, but he says that the cams displayed in BC come from the Garmin.
Because the cams that you mention have got a # in them, it seems that they have been through CSV - GPX Converter at some time so must be lurking on your computer somewhere that POI Loader is finding. Unless you have two cam GPI files on the Garmin or they are lurking in a user POI GPI somewhere.
Just a thought.
PostPosted: Tue Jan 10, 2017 5:08 pm    Post subject: Reply with quote
@dales
No, because BaseCamp is also reading the file from a cloned device which only has that specific file on it. When I do a BaseCamp search the cameras 164704#50 and 172935#50 don't show, even though they do on my 2508 when I do a where to, custom POIs, instead in BaseCamp I only get 172935#40 and 164704#70. At the very least if there was another file somewhere both should show up in the BaseCamp search box.
I did the search just to see if one camera was hiding another one in BaseCamp but that simply isn't the case. IF there was another file hiding somewhere then both, as said above, should have shown up in the BaseCamp search.
It is crazy but at least my device works correctly Very Happy
Here's a link to the file if anyone wants to play https://www.dropbox.com/s/cj93gvzb9100puc/PGPSW.gpi?dl=0
PostPosted: Tue Jan 10, 2017 5:20 pm    Post subject: Reply with quote
Good thought but before I reloaded K's convertor I searched and stripped out everything connected with it, all .gpi files etc etc
This one has really got me stumped Rolling Eyes
PostPosted: Tue Jan 10, 2017 5:28 pm    Post subject: Reply with quote
My thought was to strip the PND of the cameras gpi file then launch BC. Theoretically there should be no cameras showing in BC.
Test - remove all gpx files except for the 'fifty' one and use POILoader. All you should find in BC is 50mph cams.
Process of elimination. If they come back as 40 and 70 then we can dig deeper
Satnav:
Car Average MPG :
dales
PostPosted: Tue Jan 10, 2017 5:30 pm    Post subject: Reply with quote
When I do a Basecamp search for the camera number, I get
Gatso 172935#50 under Points of Interest (from the Garmin), and
Gatso 172935#40 under User Data (from the old .gpx files).
I take it that your rogues are listed under Points of Interest.
Dales.
PostPosted: Tue Jan 10, 2017 5:35 pm    Post subject: Reply with quote
Yep, under custom POIs
PostPosted: Tue Jan 10, 2017 5:36 pm    Post subject: Reply with quote
Correct, nothing shows, only when I load the gpi file I linked to above
Allan_whoops
PostPosted: Tue Jan 10, 2017 5:42 pm    Post subject: Reply with quote
This may seem a stupid suggestion but it isn't Garmin's camera data getting hauled in off your PND by any chance?
PostPosted: Tue Jan 10, 2017 6:02 pm    Post subject: Reply with quote
Nope, no Garmin camera files for years. Only gpi present is the one I linked to above. If I delete it nothing shows in BaseCamp, if I put it back BaseCamp shows the incorrect speeds.
PostPosted: Tue Jan 10, 2017 6:10 pm    Post subject: Reply with quote
Under normal cicumstances Garmin holds the cams in filenames with numbers and the internal info is @50.
I wonder if the 'fifty' and #50 is giving it a headache.
Process a plain csv file through POILoader and see what happens.
Satnav:
Car Average MPG :
dales
PostPosted: Tue Jan 10, 2017 7:16 pm    Post subject: Reply with quote
Suss,
I downloaded your .gpi file and loaded it into my Garmin and everything is correct.
The cameras are both #50 on the device and also when shown in Basecamp.
I can tell they are truly your cameras, because your redspeed icon is different from mine.
Dales
Page 40 of 75
