gazza_407 Occasional Visitor
Posted: Sun Jan 11, 2015 11:27 am Post subject: Re: Mazda 3 2014 model |
Has anybody had any success with this please (loading the PGPSW camera database on a Mazda 3 2014) ?
The system uses Navteq maps (now Here.com). The supplied SD card is updated via the Mazda Toobox as noted above. My vehicle was supplied with out of date maps, so these have been updated via the toolbox.
Updates are provided every 6 months, but the supplied (included) info on camera locations etc. is woefully out of date (well over 6+ months), and does not appear to hold mobile locations.
The SD card seems to hold 2 folders of interest: Speadcam: that holds 2 UK files, UnitedKingdom.spc (71 kb) and UnitedKingdom.spc.sgn (1 kb)
Poi: that holds 2 UK files, UnitedKingdom.poi (40,659 kb) and UnitedKingdom.poi.sgn (40 kb) |
Schouten Regular Visitor
![](modules/Forums/images/avatars/gallery/004.gif)
Joined: May 16, 2005 Posts: 86 Location: United Kingdom
Posted: Sun Mar 15, 2015 10:11 am Post subject: |
Did you make any progress with this? |
ROBCALLY Occasional Visitor
Posted: Sun Nov 08, 2015 1:50 pm Post subject: |
Did anybody have any luck on sorting out this problem.
Regards |
scazman Occasional Visitor
Posted: Fri Nov 25, 2016 5:18 pm Post subject: |
Hi all.
Sorry to resurrect this thread, but just wondering if anyone can shed new light onto this as I have just bought an Abarth 124 Spider which has basically the same Sat Nav as the Mazda and I want to put the PGPSW database on it.
As gazza above mentioned, there's an 'sgn' file and a 'poi' file in the car's 'speedcam' files on the Navigation sd card.
Someone on a Mazda forum mentioned putting the "iGO Myway files" onto the sd card, but could anyone who's more of an expert than me please give some step by step instructions as I'd love to use my lifetime pgpsw database on my new car.
Many thanks in anticipation.
Jon |
M8TJT The Other Tired Old Man
![The Other Tired Old Man The Other Tired Old Man](modules/Forums/images/ranks/verifier.gif)
![](http://maft.co.uk/avatars/m8tjt.jpg)
Posted: Fri Nov 25, 2016 8:35 pm Post subject: |
The iGO speedcam files are just text files that iGO converts into its own format. If the navi software is not iGO, it may work but I wouldn't hold my breath.
If you are subscribed, download the iGO file and give it a try. |
Posted: Sat Nov 26, 2016 12:42 pm Post subject: |
Cheers for the reply.
I'll investigate it further. |
Posted: Mon Dec 12, 2016 9:03 pm Post subject: |
Hi Robcally.
Sorry for the delay in replying here.
It was your post on the Mazda cx3 forum that made me join that forum just to PM you, but it seems that I can't PM someone without posting more, so I'm glad you're on here, too....
I will trawl through the thread, but did you have any luck in the end with adding the database as the thread is 235 pages long...!?
The replies on the Mazda forum from someone about the iGO files didn't make sense to me, either....
If you have sorted the problem, then I'd love to know a SIMPLE way to add the database...
Cheers,
Jon |
Posted: Fri Dec 16, 2016 5:05 pm Post subject: |
Hi Scazman,
Sorry mate still not sorted the problem.
Robcally |
Posted: Fri Dec 16, 2016 5:21 pm Post subject: |
Hi Robcally.
Thanks for letting me know anyway...I must admit that I haven't gone through all the posts in the link you kindly gave me - It started getting above my level of expertise very quickly...!
There must be some expert out there who's done it with their Mazda / Fiat....?
In the meantime, I am using my subscription for the 'cameralert' app on my phone to run alongside the sat nav- http://www.cameralert.com/
Cheers,
Jon |
Posted: Fri Dec 16, 2016 7:14 pm Post subject: |
Hi Jon.
I had the same problem as well I was hoping someone would come up with a solution I could understand and I also run Cameralert as well,
But to be honest the latest update on the car does seem not to bad at the moment.
Robcally. |
vulcanben Occasional Visitor
Posted: Thu Jan 19, 2017 1:20 pm Post subject: Mazda mzd AIO |
I have used the mazda3revolution AIO "All In one" tweak to allow me to add the pocketgps database to my 2014 Mazda 3 and it works.
First can I warn that some aspects of the AIO are dangerous and have ended up turning the CMU "coms management unit" into a brick. So at your own risk.
Having said that, the AIO problems only seem come from trying to install "Android Auto" so I can only recommend using it for the "speedcam" option.
The forum has grow to so many pages it is hard to follow, most of those pages are about the other tweaks included in AIO. Most of the problems come from the various firmware versions installed in the CMU with different American, European and Japanese versions. There are also numerous upgades to each area. but if you down load and unzip the AIO (I used versions 1.5 and 1.51 but have not tried version 2.*) and read the FAQs and instructions it is all laid out there.
I have a reasonable understanding of the process and would be happy to explain any of the steps anyone needs help with.
Posted: Thu Jan 19, 2017 1:45 pm Post subject: |
Hi vulcanben.
Many thanks for replying to this topic.
I will check the link out again, as I must admit it got waaaay beyond my knowledge and understanding very quickly..!
I will investigate the differences between the Mazda 3 system and the Fiat system (Mazda MX5 system) on my car to make sure I don't 'brick' it....
Thanks again.
Jon |
Posted: Thu Jan 19, 2017 2:29 pm Post subject: |
[quote="scazman"]Hi vulcanben.
Thanks again.
Jon[/quote]
I have no knowledge of Fiat or come to that the MX5 but if you go to the system setting page and look for the firmware version, mine is 56.00.513C-EU, you may have an old version starting with number less than 33.xx.xxx. In which case you have to update it. There is a clear warning:-
Only use with v55 or later DO NOT USE with V30/31/33 OR THE SYSTEM TO STAY AT MAZDA BOOT LOGO!!!!!
Updating is very simple but be careful to use the correct area, as the factory settings for Japan will stop the Radio working in Europe and the American version does not allow the WiFi connection ect.
AIO runs on your home computer and produces a set of files, depending on your selection of which tweaks you want to install (or remove), it will load them onto a USB, Plug that into your car and switch on the ignition - wait - after a minuet or two it will check your firmware version to insure the tweaks will work on your CMU and you can install them.
Going back to the selection of the speedcam tweak, AIO will ask which Speed Camera DataBase you want to install and give you a list or to add your own, this seemed to cause me the most problem, in the end I selected one of the existing offerings and after that had been installed in the car, I brought the Sat Nav SD card back into the house and I swapped the wrong file for our PocketGPS one, By the way I used the iGO file as the car needs a txt file. Again I can explain that further if/when you get that far.[code][/code] |
Posted: Thu Jan 19, 2017 2:49 pm Post subject: |
That's great info...
I will investigate it further.
Thanks again for your help. |
