M8TJT The Other Tired Old Man
Posted: Sat Jul 18, 2015 11:06 am Post subject: |
Just got a ta20 and it says it's not compatible |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sat Jul 18, 2015 11:43 am Post subject: |
Is it connected and powered when it says that? _________________ Where there's a will ... there's a way. |
Posted: Sat Jul 18, 2015 11:53 am Post subject: |
My crystal ball is a bit cloudy these days, so I had to try it out the old fashioned way
Seriously though. Yes, both on a 240/12v adapter in the house and in the car. The TA10 in the car pinged up with traffic as usual. I'll just pop out and give it another try.
Result:
Switched off 2569 and restarted it.
Plugged in TA20 and got a nice blue light on it.
Plugged TA20 it into the 2569 and got the incompatible cable warning.
Plugged my TA10 into it, traffic popped up pretty much straight away.
Posted: Sat Jul 18, 2015 12:09 pm Post subject: |
Hmmmm .... Kremmen hopefully will pop in later. As far as I know it should work. Could be a faulty cable perhaps
I have a TA20 with my 2508. _________________ Where there's a will ... there's a way. |
Kremmen Pocket GPS Verifier
Posted: Sat Jul 18, 2015 1:24 pm Post subject: |
I'm away from my boxed 2597 at the moment so I can't do a mix and match again till Monday.
The only time I got an incompatible warning was when I tried a USB adapter instead of the supplied car one with the male fag socket adapter on it but that was a Nuvi50.
I wonder if they have made changes in a firmware update to look for a specific antenna cable?
Find out Monday. _________________ Satnav:
Car Average MPG :
Posted: Sat Jul 18, 2015 2:21 pm Post subject: |
I've asked my contacts at Garmin about the differences between the TA10 and TA20, I'll post here if I get an answer.
Just a thought. If you've switched cables did you do a complete shut down or simply put your nuvi into standby mode? May be worth ensuring the nuvi is fully shut down by holding the on/off button until you get the turn off message, and see if that makes a difference. _________________ Where there's a will ... there's a way. |
Posted: Sat Jul 18, 2015 3:05 pm Post subject: |
Step one was to do that.
The TA10 connected OK after the TA20 had failed without an ON/OFF cycle |
Posted: Sat Jul 18, 2015 3:32 pm Post subject: |
Where are you getting the incompatible cable warning, on basic power or just the traffic?
If on basic power then it has to be the cable as I ran mine on a third party hardwire kit when I used Smartlink. _________________ Satnav:
Car Average MPG :
Posted: Sat Jul 18, 2015 3:34 pm Post subject: |
Just traffic. Charging's fine.
Looked for a TA10 but can't find one anywhere |
Posted: Sun Jul 19, 2015 11:25 am Post subject: |
I can now confirm 100% that my 2599 receives traffic from both my TA10 and TA20.
Did you say your TA20 had a straight connector because mine is at a right angle that plugs into the Garmin end like my TA10.
Sounds like a dodgy and or possibly counterfeit cable? _________________ Satnav:
Car Average MPG :
Posted: Sun Jul 19, 2015 11:46 am Post subject: |
@M8TJT
Yep, my original theory ... cable issue. Where did it come from?
Could always try to met up so you could check my TA20 on your satnav? _________________ Where there's a will ... there's a way. |
Posted: Sun Jul 19, 2015 2:09 pm Post subject: |
Kremmen wrote: | I can now confirm 100% that my 2599 receives traffic from both my TA10 and TA20.
Did you say your TA20 had a straight connector because mine is at a right angle that plugs into the Garmin end like my TA10. | No. I incorrectly said my TA10 had a straight connector. It hasn't, it has a right angled one the same as the TA20 that I have got here from eBay (don't laugh) |
Posted: Sun Jul 19, 2015 2:36 pm Post subject: |
My TA20 hasn't got the blob on it.
Yours is also a different model number, mine is a RF-279-N502-7
Mine also has P/N 320-00239-70 printed under where it says TA20 car charger so there are subtle differences _________________ Satnav:
Car Average MPG :
Posted: Sun Jul 19, 2015 3:03 pm Post subject: |
I've been having a look around and you are not alone.
It seems the ones with the P/N number are the ones that work and are in the original unit box.
The ones they sell as an accessory ,without that P/N, don't work for traffic but Garmin still sell them as a TA cable.
Crazy. _________________ Satnav:
Car Average MPG :
Posted: Sun Jul 19, 2015 3:07 pm Post subject: |
The cable marking is CSA AWM I/IIA LL109915 FT1 800C 300v18AWG XINYA-B. Not the same as yours I suspect. |
