Pocket GPS World :: View topic - nissan connect
nissan connect
Alexgray
PostPosted: Thu Nov 06, 2014 4:24 pm    Post subject: nissan connect Reply with quote
can anyone tell me what file to down load for tones for Nissan connect I am a new user and not very sure
thanks
alex
PostPosted: Mon Nov 10, 2014 5:00 pm    Post subject: Reply with quote
It might or might not be possible....
I don't know your system at all, but I'm assuming you are able to select SOME SORT of sound to the camera POIs when you set them up on the Connect?
There's no mention of adding new warning sounds in the PGPSW camera data installation instructions here, but that's not to say it isn't do-able.
Are you able to view the contents of the Connect's own storage to see if the built-in sounds appear as .mp3 or .wav or .ogg audio files?
If so, you may be able to simply add the ones from here as new files, or you may need to rename (some of) them to use the names of the built-in sounds you already had
"Settling in nicely" ;-)
actd
PostPosted: Sun Nov 16, 2014 2:22 pm    Post subject: Reply with quote
I don't know about the Connect 2 (depends on how old your Nissan is) but the Connect only has the beep tone available - this is somewhere in the sytem setup for beep tones on/off.
