Pocket GPS World :: View topic - internal memory or SD card?
mccririck
PostPosted: Thu Jul 17, 2014 7:09 am    Post subject: internal memory or SD card? Reply with quote
Is it better to have your maps on the internal memory or SD card. My Via 135 has 8GB internal, if moved the maps to a Class 10 micro SD would I notice any diffenece?
dhn
PostPosted: Thu Jul 17, 2014 8:42 am    Post subject: Reply with quote
I'd think, if anything, responsiveness of map reads/writes would be somewhat faster with a class 10 sdhc card than using the internal memory.
PostPosted: Thu Jul 17, 2014 10:01 am    Post subject: Reply with quote
Why do you say that? Is the memory clock of the SD card faster than the internal memory clock then?
Having a faster capable card, clocked at the same speed as a slower card, there will be no difference in access time (providing that the slower card works at the used clock speed).
The higher spec card will work faster provided the access clock speed is increased.
dhn
PostPosted: Thu Jul 17, 2014 12:16 pm    Post subject: Reply with quote
Valid points but why do class 4 cards often fail when used in TomTom devices?
PostPosted: Thu Jul 17, 2014 1:54 pm    Post subject: Reply with quote
Are they fast enough for the TT?
dhn
PostPosted: Thu Jul 17, 2014 3:52 pm    Post subject: Reply with quote
Not always.
mccririck
PostPosted: Thu Jul 17, 2014 6:43 pm    Post subject: Reply with quote
Hmm, so there's no real advantage in putting a micro SD card in it then?
tgold
PostPosted: Fri Jul 18, 2014 9:20 am    Post subject: Reply with quote
The premise of your original question is false; with MyDriveConnect you don't get to choose where your map is stored or have any ability to move a map from Internal to microSD storage. The value of external storage is to allow larger or more maps to be installed than the Internal storage can accommodate, a boon with the size inflation we are now seeing in newer maps.
PostPosted: Fri Jul 18, 2014 10:07 am    Post subject: Reply with quote
Well, that's scuppered that idea then!
mccririck
PostPosted: Sat Jul 19, 2014 1:32 am    Post subject: Reply with quote
Yep!
