K13ehr Lifetime Member
Posted: Sun Nov 11, 2012 11:55 am Post subject: Tom Tom antenna suitability |
I'm thinking of getting an antenna for my Tom Tom one V4 4N00.005, (yup still got one sold the other with the MH) but it's never listed can anyone point me to the correct one, it's for the van, the unit is mounted high up so never really gets to see the sky, but the view point is much better due to no sun on the screen.
If I look on Ebay as there are a few used ones, which parts do I need for a permanent fixture.
Cheers Kev. |
pcaouolte Frequent Visitor
Joined: Dec 27, 2006 Posts: 998 Location: South Lincs, UK.
Posted: Sun Nov 11, 2012 6:35 pm Post subject: |
Does your TomTom have a socket that looks like this:
The gold circle near the bottom of the picture is the socket that the remote gps antenna connects to. Newer models without the socket are not compatible with the antenna. _________________ Paul |
Posted: Sun Nov 11, 2012 8:56 pm Post subject: |
If the socket on the rear is the same as the picture posted earlier the one you need is with an MCX plug, the mMCX is about half the diameter of that used on the TomTom One - Mike |
Posted: Mon Nov 12, 2012 7:41 am Post subject: |
mikealder wrote: | If the socket on the rear is the same as the picture posted earlier the one you need is with an MCX plug, the mMCX is about half the diameter of that used on the TomTom One - Mike |
Thanks Paul and Mike, I'll check out the back of the unit and measure the antenna socket.
Is mMCX a typo or does it mean MiniMCX.
Kev. |
Posted: Mon Nov 12, 2012 8:31 am Post subject: |
there are two types mMCX and MCX you need the MCX style plug - Mike |
Posted: Sun Nov 18, 2012 5:39 am Post subject: |
mikealder wrote: | there are two types mMCX and MCX you need the MCX style plug - Mike |
Sorry Mike, I'm away for a few days, can't sleep so trying to catch up on my messages.
I'll check the unit when I get back.
Kev. |
Gee-Pee Lifetime Member
Joined: Feb 10, 2005 Posts: 1951 Location: Mostly somewhere in Essex
Posted: Sun Nov 18, 2012 11:47 am Post subject: |
I might have a suitable one for your device. The label on the unit is 4V00.013. It has a VERY small pin plug on it. I have looked on the TT shop website, but cannot find any antennas there now.
PM me if you are interested.
PS It is NOT the one compatible with Paul's picture, above. _________________ Gee-Pee
Lifetime member PGPSW - time rapidly decreasing |
Posted: Tue Nov 20, 2012 1:20 pm Post subject: |
Gee-Pee wrote: | I might have a suitable one for your device. The label on the unit is 4V00.013. It has a VERY small pin plug on it. I have looked on the TT shop website, but cannot find any antennas there now.
PS It is NOT the one compatible with Paul's picture, above. |
Hi GeePee,
Sorry for the delay, only got home last night.
I don't know what the correct part number would be so can't help there.
but here's a picture of my antenna socket I don't know how to put a pic in the post, I'm still no wiser as to which one I need, or am I just being a bit thick and missed it.
The whitish thing is in place of a windscreen mount, a Klett patch it never falls off once it's in place, Aldi/Lidl do them.
Kev. |
Posted: Tue Nov 20, 2012 1:53 pm Post subject: |
See HERE, Kev. The picture is a bit small, but you will probably see that this is a male plug with the top end of it recessed into a black plug all of which goes into the device socket.
You are still welcome to it IF you are confident that it is what you want, but I suspect not. Mike A might like to cast an opinion on it. _________________ Gee-Pee
Posted: Tue Nov 20, 2012 3:10 pm Post subject: |
Gee-Pee wrote: | See HERE, Kev. The picture is a bit small, but you will probably see that this is a male plug with the top end of it recessed into a black plug all of which goes into the device socket.
You are still welcome to it IF you are confident that it is what you want, but I suspect not. Mike A might like to cast an opinion on it. |
Do you have a micrometer to check it's size? to see if it's anywhere near or measure your TT socket mine = 4.5mm.
You have a PM |
Posted: Tue Nov 20, 2012 3:27 pm Post subject: |
K13ehr wrote: | Gee-Pee wrote: | See HERE, Kev. The picture is a bit small, but you will probably see that this is a male plug with the top end of it recessed into a black plug all of which goes into the device socket.
You have a PM |
Don't have a micrometer, but length of metal part of plug is ca 11mm, diameter is ca 2mm, depth of metal part surrounded by black plastic is about 4mm.
Have responded to your PM. _________________ Gee-Pee
M8TJT The Other Tired Old Man
Posted: Tue Nov 20, 2012 3:37 pm Post subject: |
@K13ehr. The plug that GeePee has wil not fit! His is like an earphone plug which fairly obviously will not fit into your co-axial socket without considerable force which will break either the plug or the socket or both and won't work even if you achieve complete penetration. |
Posted: Tue Nov 20, 2012 4:41 pm Post subject: |
M8TJT wrote: | @K13ehr. The plug that GeePee has wil not fit! His is like an earphone plug which fairly obviously will not fit into your co-axial socket without considerable force which will break either the plug or the socket or both and won't work even if you achieve complete penetration. |
I'll forego the opportunity for smut, Graham I assume you'll have read the above, so thanks for the generous offer, shame it's of no use to me though.
I'm still no wiser as to which one I need to get then, 4.5mm plug wanted
Kev |
Posted: Tue Nov 20, 2012 5:00 pm Post subject: |
The one that you want looks like a bit like a teensy-weensy TV arial plug of the old fasioned plug in type, not one of your new fangled screw on type.
Mikeader has made two posts above. Both of which tell you the type that you require But just in case you missed it, it's an MCX style plug.
Search eBay for 'gps antenna mcx' there are shedloads of them, mainly from china for less than a tenner. I've bought stuff from China before on eBay and had no problem, other than the expected extended delivery time (10 days or so) |
Posted: Tue Nov 20, 2012 5:42 pm Post subject: |
Oh well! Hope you find what you want, Kev. _________________ Gee-Pee
