harley-noj Regular Visitor
Joined: Mar 18, 2006 Posts: 86 Location: South Yorkshire
Posted: Sun Jul 01, 2012 7:54 pm Post subject: |
Ok I appear to have my TT720 working again.
As removing all files from ephem did not work for me?
This is my solution
I connected unit to computer and deleted all files from the SD card (I ran everything from SD)
Copied a previous backup to SD card (we all keep backups don't we)
So now I have ap 9.43 map v885
Ran TT home and did not change or update anything.
Remove from computer
It works and shows correct home location!!!!
Reconnect to TT home and update map etc.
Do not update Quickfix files via home
Remove from computer and it seems fine
Lets hope its now Ok
Noj |
Andy_P Pocket GPS Moderator
Posted: Sun Jul 01, 2012 8:12 pm Post subject: |
When you say "reconnect to Home and update map etc." I'm guessing you HAD to update the software again too?
So are you actually back to exactly the same software and map version as you were on when you were seeing the problem?
That might be quite an important diagnostic clue.... _________________ "Settling in nicely" ;-) |
Guivre46 Frequent Visitor
Joined: Apr 14, 2010 Posts: 1262 Location: West London
Posted: Sun Jul 01, 2012 10:35 pm Post subject: |
Had this problem. Just connected my 530 to Home and found a new QgpsF [that was not there 5 hours ago], downloaded it and nothing else, and my 530 is now back to normal. Diagnosis complete I think? _________________ Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom |
Posted: Sun Jul 01, 2012 10:48 pm Post subject: |
Hi Andy_P
Yes to your question.
The only thing I did not update was quickfix.
I see from Guivre46 that there is a new file.
I think I'll wait and see what others think about this before I try it.
To be honest I've had enough for 1 day
All the best
Noj |
Posted: Sun Jul 01, 2012 10:54 pm Post subject: |
oh yes....I'm a NatWest customer as well.
Worn down indeed. _________________ Mike R [aka Wyvern46]
Blitzer Occasional Visitor
Posted: Sun Jul 01, 2012 11:30 pm Post subject: |
Well I experienced the same problem today after having not used my 530 for a while. I updated it yesterday ready for use today, but on trying it today found my position was not being correctly positioned on the TT. The end results being that the route was constantly beng re-calculated as the TT kept trying to place me on the nearest road to my position.
Anyway, having done a bit of re-search and following the links on this forum I did the following with the TT attached/connected to my PC whihch seems to have fixed teh problem...
ephem - deleted all the files from within this folder on the TT. (I don't have a SD card on my 530, but perhaps those of you that do may need to see if this folder appears on both the TT memory and the SD card and delete all the files inside both folders?)
Deleted all the files from the folder \Documents\TomTom\HOME\Download\complete\ephemeris
Disconnected the TT via the home software.
Turned off the TT.
Turned TT back on - said NO when asked if I wanted to connect to PC.
Confirmed TT was reporting my position correctly (it was).
Turned off the TT.
Turned TT back on - said YES when asked if I wanted to connect to PC.
Did an Update and got the Quick GPS Fix (Nothing else offered).
Turned off the TT.
I hope this is some help to other people. |
alanlakes Lifetime Member
Joined: Dec 28, 2005 Posts: 100 Location: Chevington, Suffolk
Posted: Mon Jul 02, 2012 3:27 pm Post subject: |
Thanks Blitzer
Your solution works on my 910.
Alan _________________ Tomtom Go 6200, Tomtom GO Android app, Garmin GPSMap 62stc, Garmin Oregon 450, Memory map V5 & V6, Moto G6, CamerAlert, Copilot Premium, MM Tracker. |
MrT Frequent Visitor
Joined: Nov 14, 2003 Posts: 2143 Location: Surrounded by A1, M1 & M25
Posted: Mon Jul 02, 2012 3:32 pm Post subject: |
I wonder if the leap second on 30th June had any effect on this? _________________ Drivelux |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Mon Jul 02, 2012 3:33 pm Post subject: |
It seems it did. The replacement gps file now available via Home resolves the issue to my understanding. _________________ David |
Biggles500 Occasional Visitor
Joined: Aug 13, 2010 Posts: 36 Location: Hemel Hempstead
Posted: Mon Jul 02, 2012 5:10 pm Post subject: |
I've had the same problem with my 720 shifting its position up to 500 metres away.
Did all the suggested solutions reset, deleting gps file etc. then downloading the updated file. However the problem was still there!
Deleted the gps file again from the 720 and normal operation resumed.
So I'm not going to download THAT file again, until I'm sure it's fixed. _________________ Garmin Drivesmart 50 LMT-D App 5.90
Full Europe Map 2024.20 |
Anita Pocket GPS Moderator
Joined: Mar 15, 2006 Posts: 3219 Location: Windlesham, Surrey
Posted: Mon Jul 02, 2012 5:33 pm Post subject: |
I've never felt the need to download the QuickGPSfix. My 720 gets a satellite lock pretty quickly anyway.
This isn't the first time the file has screwed up devices, and I'd rather restrict the possible sources of problems caused by TomTom to essential files. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Apple Occasional Visitor
Posted: Mon Jul 02, 2012 8:02 pm Post subject: |
Deleting the quickfix files on my mac and 920 before downloading the updated version seems to have worked on a small trip out tonight to check that it held the road position.
Unfortunately, I now get an error message in Home effectively saying that files are missing. I deleted the files via finder (equiv to file manager / windoze explorer) rather than using the 'manage my Tomtom' section of home as it doesn't let you get to the actual 'system' files.
Would trying to put something back just confuse it as the numbers would be out of sequence? I guess it stores old files as QuickGPSfix-18, QuickGPSfix-19 etc.
Andy |
Posted: Mon Jul 02, 2012 9:46 pm Post subject: |
I don't know what files it thinks you're missing, but emptying the "ephem" folder completely shouldn't generate any error messages.
Sure nothing else got selected by accident? _________________ "Settling in nicely" ;-) |
Posted: Mon Jul 02, 2012 11:40 pm Post subject: |
On the Mac I took out all the files / folders in
tomtom/downloads/complete/ephemeris/
but left that folder
An in the 920 ephem folder:
ee_meta.tlv
ee_meta.txt
packedephemeris.ss
Is this more than I should have taken out? Downloading the latest guickgpsfix has replaced the above files with the new versions... |
Posted: Tue Jul 03, 2012 12:02 am Post subject: |
That's what I've removed in the past. So afraid I can't explain the error message you got. _________________ "Settling in nicely" ;-) |
