Pocket GPS World :: View topic - entering post codes
entering post codes
bazzza
PostPosted: Fri May 11, 2012 6:27 pm    Post subject: entering post codes Reply with quote
I haven't been on the forum for a while and haven't used my Go520 for a while either. I have searched for info on this. Have I missed something or has there been a change that stops me from entering the second part of a post code (no space bar)?
I have a feeling that the answer is going to embarass me but I have to ask.
Bazzza
TTGO520 Version 9.430
Western & Central Europe Maps
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Fri May 11, 2012 7:22 pm    Post subject: Reply with quote
Are there any files in the zip folder on the device? - If not simply copy the contents of the zip folder from your backup storred on the PC to the zip folder on the device - Mike
PostPosted: Fri May 11, 2012 7:31 pm    Post subject: Re: entering post codes Reply with quote
bazzza wrote:
... stops me from entering the second part of a post code (no space bar)?
You don't need the space bar. Just enter the digits without the space - AB118AZ
bazzza
PostPosted: Fri May 11, 2012 8:01 pm    Post subject: Entering Post Codes Reply with quote
Sorry Mike, that goes a little out of my comfort zone. There doesn't appear to be a zip folder on the device and the backup folder on the pc was empty. Backed up now, but of course, no zip folder.
Oldboy, I tried ignoring the space but the device just ignores the second part of the code.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Fri May 11, 2012 8:35 pm    Post subject: Reply with quote
You can download the postcode data by clicking Here once saved to your PC simply unzip the download straight to the drive letter associated with your TomTom (it needs to be plugged in to the PC and switched on) - This will put the required data on your device to resolve your issue - Mike
bazzza
PostPosted: Fri May 11, 2012 9:10 pm    Post subject: entering post codes Reply with quote
Sorry Mike, It didn't work. I did what you said and the files are now in the device, but they don't make any difference. It still only responds to the first part of the post code.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
dhn
PostPosted: Fri May 11, 2012 9:21 pm    Post subject: Reply with quote
Did the files get put into a FOLDER called zip in the root of the unit? (NOT within the specific map folder)??
PostPosted: Fri May 11, 2012 9:59 pm    Post subject: Reply with quote
Here's how the folder and file structure should look on the Go...
"Settling in nicely" ;-)
bazzza
PostPosted: Sat May 12, 2012 6:36 pm    Post subject: entering post codes Reply with quote
Sorry for the delay. Wife has different priorities.
In a folder called Zipcode there is another folder called Postal_code_file_for_UK_TeleAtlas _maps
In that folder are:
Great_britain.postal
Great_britain_postal_teleatlas_603.cab
Great_britain_postal_teleatlas_603.toc
Great_britainpostal.ver
Nederland.postal
Nederlandpostal.ver
Sorry, I could do a screen dump of my files but I don't know how to post a picture.
Thanks for your patience.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Sat May 12, 2012 6:58 pm    Post subject: Reply with quote
Use Windows Explorer to rename the folder zipcode to just "zip" (without the "") then you full postcode look up should work - Mike
bazzza
PostPosted: Sat May 12, 2012 7:32 pm    Post subject: Reply with quote
Sorry Mike, it still doesn't work. e.g. if I put in my home postcode it just comes up with the name of the village. The response is the same whether I put in the second part of the postcode or not.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
Daggers
PostPosted: Sat May 12, 2012 7:36 pm    Post subject: Reply with quote
Are the files Great_britain.postal, etc. still in the folder called Postal_code_file_for_UK_TeleAtlas _maps, or are they directly in the folder called zip?
They should be in the zip folder.
Garmin DriveSmart 50 LMT-D
bazzza
PostPosted: Sat May 12, 2012 7:56 pm    Post subject: Reply with quote
They were still in the folder called Postal_code_file_for_UK_TeleAtlas _maps.
I moved them into "zip"and it's ok now. Thanks for your patience.
In the zip folder now are:
Nederland.postal
Nederlandpostal.ver
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
PostPosted: Sun May 13, 2012 5:45 pm    Post subject: Reply with quote
You've still got the original downloaded archive files (.cab and .toc) so you could delete those if you want.
The .ver file is handy because it's a text file that says what version of the postcode file you have.
But all you actually need is the "zip" folder and the four files shown in my picture in post #8. Any other files will just be ignored by the TomTom.
bazzza
PostPosted: Sun May 13, 2012 11:09 pm    Post subject: entering post codes Reply with quote
Thanks Andy, I'll tidy it up.
Bazzza
Iphone 6
TT Via 135M
GO520 WiFi
