Pocket GPS World :: View topic - TomTom App 9.401 - Released
Goto page Previous  1, 2, 3, 4, 5, 6  Next
clay
PostPosted: Tue Mar 06, 2012 2:01 pm    Post subject: Reply with quote
Thanks dennis the zip folder was missing from my tomtom, ive downloaded your zip file & I have my street names back, I'll give this new version a try & see how i get on Smile
s3dbw
PostPosted: Sat Mar 10, 2012 10:24 am    Post subject: Reply with quote
Any body else found that the new version does not display the pocketgps speed camera icons properly?
Daggers
PostPosted: Sat Mar 10, 2012 10:36 am    Post subject: Reply with quote
Yes - you need to download the 24x24 pixel icons to get much clearer images.
Garmin DriveSmart 50 LMT-D
s3dbw
PostPosted: Sat Mar 10, 2012 10:50 am    Post subject: Reply with quote
That might explain things, thanks for the tip
regards
MrT
PostPosted: Sat Mar 10, 2012 11:16 am    Post subject: Reply with quote
Is there a link to the 24x24 icons?
Also I notice that the Camera Database still has the 22x22 & 44x44 icons, will this change and are both these sizes now obsolete with the latest 9.041 software?
Drivelux
AliOnHols
PostPosted: Sat Mar 10, 2012 11:28 am    Post subject: Reply with quote
http://www.pocketgpsworld.com/speed-camera-icons.php
Garmin Nuvi 2599
SatMap Active 10 & 20.
PostPosted: Sun Mar 11, 2012 12:51 am    Post subject: Reply with quote
I think it's probably best to wait to see if TT fix THEIR cock-up with the 22x22 icons before PGPSW do all the donkey work to change the icons over. They've been made aware of it.
As for the 44x44 icons, they are definitely still being used with v9.041
Here's what the icons look like on a GO940 running v9.401.
Top half of each example is with just the standard "normal" icon (although mine are 24x24 icon), bottom half is with a 44x44 "X2" icon.
"Settling in nicely" ;-)
jm202067
PostPosted: Tue Mar 13, 2012 7:52 pm    Post subject: Reply with quote
I have connected my 530 and it has updaded the gps quickfix and map corrections but no application update is showing as available. Mine is still showing 8.398 and has not shown a application update available for over 18 months. Am i doing something wrong here as a friend with the same device had 9.4 offered for update when he connected his identical 530?
Guivre46
PostPosted: Tue Mar 13, 2012 11:43 pm    Post subject: Reply with quote
The application for a 530 before the updates should have been 8.351. Have you downloaded a non-standard version from somewhere? I expect that if you load 8.351 you will be offered 9.40x
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
jm202067
PostPosted: Wed Mar 14, 2012 11:42 am    Post subject: Reply with quote
I have only downloaded updates onto it in the past that we're showing as available from Tomtom home.
Guivre46
PostPosted: Wed Mar 14, 2012 12:21 pm    Post subject: Reply with quote
Standard first thing to try:
1. Make a back-up directly to your computer. Don't rely on Home to do this, it loses stuff.
2. Use Home to remove your application from your 530 and from your computer.
3. Use Home to 'update your device'. You may have to run through several updates of the different softwares that have been issued for 530s, but eventually get to 9.401.
Note that 9.401 has some flaws and alterations, the main one being the status bar layout. If your current application is running as you wish you may want to stick with it?
Read some more on the topic in the forum before making up yoiur mind.
Kia In-dash Tomtom
PostPosted: Wed Mar 14, 2012 12:43 pm    Post subject: Reply with quote
Here's a bit of background info... v8.398 is a TomTom WORK software version, never intended for "normal" TomToms.
But some people manually downloaded and installed it because they wanted the specific vehicle-size features it offered.
Apparently, for a brief period in June '11, it was offered by Home accidentally!
jm202067
PostPosted: Wed Mar 14, 2012 1:12 pm    Post subject: Reply with quote
Yep, those instructions worked fine. I deleted the application then was offered 8.351 update. After installing this i was then offered the 9.401 update.
My Tomtom was a replacement for my previous faulty one and came direct from Tomtom. This may have been the reason how it somehow had the 8.938 sofware version installed?
Thanks for your help :-)
PostPosted: Wed Mar 14, 2012 3:06 pm    Post subject: Reply with quote
Ha Ha! It's not the first time they've done that either!
GO 530 Repair by TomTom
cazian
PostPosted: Sun Mar 18, 2012 9:15 am    Post subject: Reply with quote
Installed the 9.401 on my 750 Live, and this morning (albeit a Sunday morning), connecting to Traffic within about 1 minute. Seems much quicker, but I suppose testing again during a busy rush hour might give different results?
Page 5 of 6
