Ash10 Pocket GPS Verifier
Posted: Tue Aug 23, 2011 7:21 pm Post subject: |
Camera Manager v3.6 beta now available
This fixes a bug with the automatic creation of certain voice warnings for alert speeds greater than 100 (kph).
Also fixes the issue with missing downloaded zip files (ie: if they have been inadvertently deleted from the POI directory, or new database regions have just been selected).
Download link below (same as before). |
westcatford Occasional Visitor
Posted: Thu Aug 25, 2011 10:54 am Post subject: |
I hope this is the correct way to report that (repeated) attempts to download the 3.6 Beta produce the following error message:-
"Gateway Anti-Virus Alert
This request is blocked by the SonicWALL Gateway Anti-Virus Service. Name: Onescan.A_7 (Trojan)"
I've tried reporting it to Zen but they're always engaged.
Apologies in advance if I should have reported this in some other way. |
Posted: Thu Aug 25, 2011 11:12 am Post subject: |
westcatford wrote: | "Gateway Anti-Virus Alert
I've tried reporting it to Zen but they're always engaged. |
Nothing to do with Zen (the ISP) - it's your AV getting a false positive (A quick Google search suggests that this isn't uncommon for SonicWall)... |
Posted: Thu Aug 25, 2011 1:13 pm Post subject: |
Thank you for the prompt response.
Unfortunately (in terms of an easy answer) I don't use SonicWall. And, for what it's worth, turning off my a/v (Eset) and my firewall (Win7) have no effect on the problem.
But thanks anyway. |
Posted: Thu Aug 25, 2011 4:47 pm Post subject: |
I've established that it's my ISP's firewall that is blocking the file. They also tell me - false positive or not - that Zen are reporting it as infected as well.
Is there any other mechanism by which you could suggest I access the file? |
deeranwith Lifetime Member
Posted: Sat Nov 12, 2011 1:59 pm Post subject: Camera Manager 3.5 beta issues |
I have been using 3.6 beta for sometime now and it works fine with my Win 7 ultimate and IE9 setup. EXCEPT once it finds an update and you install it, it continues to remind you. Manual cancellation works but this is not the behaviour experienced with previous versions.
Has anyone had a similar issue? |
digitalker Occasional Visitor
Posted: Sat Nov 12, 2011 2:24 pm Post subject: Re: Camera Manager 3.5 beta issues |
deeranwith wrote: | I have been using 3.6 beta for sometime now and it works fine with my Win 7 ultimate and IE9 setup. EXCEPT once it finds an update and you install it, it continues to remind you. Manual cancellation works but this is not the behaviour experienced with previous versions.
I think this behaviour started some time ago when Garmin last updated the POI Loader software. Its being happening with CM 3.0 as well. I'm hoping Ash10 can fix in due course. |
Posted: Fri Nov 18, 2011 12:17 pm Post subject: |
Thanks I will await Ash's pronouncement on this bug in due course.
M |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Fri Nov 18, 2011 4:48 pm Post subject: |
Yes, I think digitalker has got it.
With PoiLoader.exe version 2.6, all was well.
With Poi Loader.exe version 2.7, the Ash icon continues to flash.
(Note the subtle change of name of the exe).
Hope this helps.
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Metblackrat Regular Visitor
Posted: Fri Dec 23, 2011 6:00 pm Post subject: |
I have a problem since updating to 3.6 beta.
If I open Camera manager, the program does not respond, it just sits in the tray and I cannot do anything with it. I can only close it in task manager. However, if i open a second instance of camera manager, that one runs fine.
The first program seems to create some erroneous files in my poi folder called output.csv, specs.tmp, redlight.tmp, gatso.tmp and mobile.tmp.
I have tried deleting all instances of the program and re-downloaded it but that hasn't helped. Does anyone know where the settings are stored?. Perhaps this file is corrupted.
Any ideas?. |
Posted: Sat Dec 24, 2011 6:56 pm Post subject: |
Sorted it by changing every possible setting in camera manager, closing it, then re opening it and putting the settings back as they were.
Seems like the settings were corrupted. |
kkk Occasional Visitor
Posted: Thu Mar 22, 2012 9:57 am Post subject: Re: Camera Manager 3.5 beta issues |
digitalker wrote: | deeranwith wrote: | I have been using 3.6 beta for sometime now and it works fine with my Win 7 ultimate and IE9 setup. EXCEPT once it finds an update and you install it, it continues to remind you. Manual cancellation works but this is not the behaviour experienced with previous versions.
Go into Properties on POILoader and where the name is in
Target take out the space between `i` and `L` and apply.
It then it works fine. |
TheGavsta Occasional Visitor
Posted: Fri Mar 23, 2012 2:35 am Post subject: |
Hi All
Is there any workaround to include the French and Swiss cameras in the European download for Camera Manager?
Thanks |
borgmaster Occasional Visitor
Joined: Dec 28, 2004 Posts: 25 Location: Doncaster. South Yorkshire
Posted: Fri May 18, 2012 10:22 am Post subject: |
Since upgrading to FF 12 my computer at start up keeps asking for a digital certificate for CM. I have to click on run for my computer to continue to load and eventually CM is loaded ok. Is there a way of getting round this? I`m using Vista 32 Bit home premium. |
M8TJT The Other Tired Old Man
Posted: Fri May 18, 2012 3:10 pm Post subject: |
It took me about 15 seconds to Google for this. Does it help? |
