Pocket GPS World :: View topic - TT 550Live - Application update....(v9.061)
Goto page Previous  1, 2
Guivre46
PostPosted: Fri Oct 21, 2011 9:58 pm    Post subject: Reply with quote
Andy_P wrote:
Auto-switch on is good isn't it? Smile But if it's anything like the version I've seen, they still need to do some work on the wording of the menus to select it.
With 9.061 I can't find any option to deselect auto-switch on?
Mike R [aka Wyvern46]
Go 530T - unsupported
Go550 Live [not renewed]
Kia In-dash Tomtom
PostPosted: Fri Oct 21, 2011 10:49 pm    Post subject: Reply with quote
See Ian's post above... It looks like they've combined it with the 'auto-off' selection option now.
"Settling in nicely" ;-)
Guivre46
PostPosted: Sat Oct 22, 2011 10:21 am    Post subject: Reply with quote
If you select auto-off in Battery Saving Preferences, that setting is lost every time the device reboots eg on disconnecting from Home. But it still has auto-on, so seems no way of changing it?
Kia In-dash Tomtom
IanS100
PostPosted: Sat Oct 22, 2011 12:53 pm    Post subject: Reply with quote
I've just checked this & as far as the settings go my 550 is the same, the setting is lost when disconnecting from home but it never the less continues to switch on & off with power connect / disconnect ie
Disconnect from home - disconnect from power 550 goes off
Power connect - 550 on
Power disconnect - 550 off etc etc
On checking the Power Saving setting the box is ticked but the 550 ignores it.
Untick the box & then tick it again & it then seems to function correctly as per the setting. I think the reboot screws up that command & it appears to be ticked when in fact it is not Shocked
Guivre46
PostPosted: Sat Nov 05, 2011 8:39 pm    Post subject: Reply with quote
Also found that the update scrambled third party POI icons and titles eg the National trust icon was captioned 'Kia Dealers England and Wales'. Removed the POIs and reloaded - fine now.
Edit: Should have said I noticed this in the 'Warn when near POI' section.
Kia In-dash Tomtom
JimmyTheHand
PostPosted: Sun Nov 06, 2011 12:22 pm    Post subject: Re-booting Reply with quote
My 550 doesn't seem to have rebooted since upgrade - has TomTom fixed it or am I had a lucky week?
J.
IanS100
PostPosted: Sun Nov 06, 2011 12:33 pm    Post subject: Re: Re-booting Reply with quote
Don't fret it'll be back to normal with the next update & maybe with a few extra reboots to compensate Laughing
JimmyTheHand
PostPosted: Sun Nov 06, 2011 1:25 pm    Post subject: Re: Re-booting Reply with quote
Of course that requires me to connect it to TomTom Home - which only happened because I had a full backup
J.
Guivre46
PostPosted: Sun Nov 06, 2011 4:38 pm    Post subject: Reply with quote
I've had a couple of reboots, both times seemed linked to problem with connecting to Live services. Have also had to reboot once when voice guidance ceased to work.
Kia In-dash Tomtom
JimmyTheHand
PostPosted: Sun Nov 06, 2011 9:10 pm    Post subject: Reply with quote
it always seemed related to Live Services in ver 9.58 and I am sure it seemed to change how often when they altered the range of the Traffic (I wonder whether it was bad packets from server caused the process to crash)
J.
andy-c1
PostPosted: Mon Nov 07, 2011 10:35 am    Post subject: Reply with quote
only just updated ...is it me or is the button pushing a little quicker ie getting to poi location to enter a poi
TomTom 5001
DaveNN
PostPosted: Mon Nov 14, 2011 2:22 pm    Post subject: Reply with quote
ditto...
More worrylingly for me is that the TT now simply freezes for no apparent reason.
I've also noticed that it does appear to take a bit longer to get a GPS signal.
Still...it boots up on ignition now..which is nice! Thumbs Up
Jaguar XF R Sport AWD
Onboard nav with live stuff, weather, news and stuff.
NextBase Duo DashCam
Running Cameralert via Samsung S7 Edge
psyskiesman
PostPosted: Mon Nov 14, 2011 6:18 pm    Post subject: Reply with quote
DaveNN, I had that problem as well. Ran clearflash tool 3 times and all seems to be OK now.
JimmyTheHand
PostPosted: Tue Nov 15, 2011 8:36 pm    Post subject: Re: Re-booting Reply with quote
Answer is lucky week - had a couple of reboots now Sad
J.
Guivre46
PostPosted: Sat Nov 19, 2011 12:54 pm    Post subject: Reply with quote
The auto-on function seems independent of the battery saving option for 'shut down when disconnected from power'. I suspect that the device may shut down after a certain period of inactivity - I just haven't wanted to hang around to see it actually happen?
Kia In-dash Tomtom
Page 2 of 2
