Pocket GPS World :: View topic - HP Color LaserJet 2605dn, is it beyond economic repair?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area
Privateer
PostPosted: Wed May 04, 2011 6:27 pm    Post subject: HP Color LaserJet 2605dn, is it beyond economic repair? Reply with quote
I have a HP Color (their spelling not mine) LaserJet 2605dn (duplex and networked) printer which I bought on 21 May 2008 for use at home, so it’s nearly three years old. The printer has developed three faults:
1. Constant jams (either the paper tray or the printer’s tray locking mechanism is broken) which can only be avoided by constantly holding the main paper tray day in situ.
2. Blurred colour printing on the middle to bottom part of each page (duplex or simplex)
3. Seems to spend a lot of time initialising and calibrating itself.
I think that it'll cost me at least £100 + VAT just for an engineer to visit/take it away before parts are taken into consideration. As new printers start around the £250 range I don't want to spend too much money on it so I'd rather have a go at fixing it myself - what's the worst that can happen? Wink
Does anybody here have any experience of the HP Color LaserJet 2605dn, especially fixing faults such as I've listed above.
Can you recommend anything, i.e. parts kits to fix the above?
Thanking you in advance for you help.
Robert.
Garmin Camper 770 LMT-D
Border_Collie
PostPosted: Wed May 04, 2011 7:47 pm    Post subject: Reply with quote
Had similar on an injet printer and found the 'rollers' were contaminated, roughened 'em up with some sandpaper and got a few more years out of it. May be worth checking first.
PostPosted: Wed May 04, 2011 7:59 pm    Post subject: Reply with quote
That blurring might be the drum?
I have a color Laserjet 2550L you can have if you like, you're not far away. Still on original supplies - when I discovered the price of the cartridges and drum, I didn't dare use it - 50% more than the original price of the printer complete. It may well not be good enough for you if you've been using a decent one - page print is limited by memory Dim. Look it up.
Privateer
PostPosted: Sun May 15, 2011 5:43 pm    Post subject: Reply with quote
Hi Dennis,
Thanks for the kind offer of your HP Color LaserJet 2550L, however I won't take you up on it if you don't mind. It (the 2550L) is probably incompatible with my 2605dn for cannibalising for spare parts. The 2550L certainly uses different toners than the 2605dn.
By the way, why do printer manufacturers (especially HP) create so many different toners? Why can't they get their printers to all use the same toner?
I think that I might as well buy a new laser printer, pay £50 extra for a three year warranty (next day engineer to home) and expect it to last about three years. If the new printer can use the same toners as my 2605dn then I'm in the money because it's the toners that are expensive.
Robert.
PostPosted: Sun May 15, 2011 7:39 pm    Post subject: Reply with quote
I'd bet a reasonable sum that the new printer will NOT use the same cartridges. I'd suggest the only way to check that is to look at the packaging on a new cartridge box for the current printer - you know, where they say which printer it fits and lists all of them. Your printer is fairly old in New Tech terms, so I'd say it's odds on that the cartridges are for older printers which you won't be able to buy now. I once had an A4 and an A3 printer (HP) which used the same colour inks, but different blacks.
It would be simple I suppose for HP to have all printers using the same toners, but it might slightly limit the size and shape of new machine development. But worst of all, you'd be able to use your old toners in your new printer! Like any wise virgin, I presume you always have spare cartridges in the house/office so that there will be a set left over when the printer packs up! Let's face it, the profit isn't in the price of the printer, it's in the toner/ink they sell you - new printers supplied with only "starter" ink/toner quantities - maybe half full. I paid less than £200 for my color laser printer, four cartridges each £60+ and the drum (limited life) £80+. It's a racket! Have you ever considered why printer cartridges are not transparent to let you see how much ink/toner is left in there? Fortunately (for HP et al) they give you a chip in the cartridge which the printer program can read to tell you to replace a cartridge before it's empty!!
PostPosted: Sun May 15, 2011 9:29 pm    Post subject: Reply with quote
I'd much rather change the toner when it was empty Very Happy
PostPosted: Sun May 15, 2011 9:36 pm    Post subject: Reply with quote
I MUST stop doing subtle
I MUST stop doing subtle......
PostPosted: Sun May 15, 2011 9:42 pm    Post subject: Reply with quote
That was only 16. I thought I told you to do 50 Shocked Twisted Evil
Privateer
PostPosted: Mon May 16, 2011 11:50 am    Post subject: Reply with quote
Hi Dennis,
DennisN wrote:
Like any wise virgin, I presume you always have spare cartridges in the house/office so that there will be a set left over when the printer packs up.
You are absolutely correct to presume that I have spare cartridges in the home ready to replace as and when the chip decides that toner cartridge is empty, even though the toner cartridge still has plenty of toner left in it! Rolling Eyes
Fortunately, I wait until the display on the printer reads just less than half, before I order new toner and at the moment I have no spare toners left at all! Very Happy
As I've only put about four sets of genuine HP toner through my HP 2605dn laser printer, in three years, before it went wrong, I'm very tempted to used refill non-HP toners. Evil or Very Mad
I know that non-HP toners are supposed to be bad for a printer but as toners are the most expensive part of the printer and if you have to replace the printer every 3 years or every 4 sets of toners then HP are making a big statement that as their own products are of such poor quality then using third party replacements won't make too much of a difference! Twisted Evil
Also, are there not toner chip resetting devices that "fool" the toner cartridge into thinking that it's full again to allow use of all of the toner? Instead of throwing out a perfectly good toner cartridge with still 20% to 30% toner left?
Robert.
PostPosted: Mon May 16, 2011 7:27 pm    Post subject: Reply with quote
My first laser printer was black and white and pre-dated the chips. So I was told about low toner simply by the print quality. When it got bad, I took out the cartridge, shook it up briskly and got quite a lot more copies out of it!
PostPosted: Mon May 16, 2011 10:03 pm    Post subject: Reply with quote
Drifting off-topic a bit.
I've got an Epson inkjet which uses 6 separate ink cartridges, all of which have the dreaded Epson "replace when half-full" chip.
For about £7 I bought a chip resetter tool and the savings have been immense. I reckon I can reset each cartridge twice before it's REALLY empty, so by that reckoning it must still be at least half to two-thirds full when Epson expect me to change it! Evil or Very Mad
"Settling in nicely" ;-)
PostPosted: Mon May 16, 2011 10:34 pm    Post subject: Reply with quote
I've done the same for my Canon. Now buy chipless carts from Inkredible, swap the chip, reset it, orft I jolly well go Very Happy . Tried refilling but it's too messy Sad
Anita
PostPosted: Mon May 16, 2011 11:37 pm    Post subject: Reply with quote
My Canon will still print after telling me that the ink has run out without resetting chips or anything. I just ignore the message. Confused
Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21
PostPosted: Tue May 17, 2011 7:44 am    Post subject: Reply with quote
So does mine, but by resetting the chip, you get an idea of how much ink yoy have left like the original. Anybody know if the print head of an inkjet is damaged if you print with a (realy) empty ink cartridge, or is it just an urban myth?
Anita
PostPosted: Tue May 17, 2011 9:46 am    Post subject: Reply with quote
I see. I thought you meant you had to reset it before it would print.
I assume it just shows it as full again, not how much ink is actually left?
Anita
UK map 1130.12368
Samsung Galaxy S21
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area All times are GMT + 1 Hour
