LesP2008 Lifetime Member
Posted: Wed Jan 19, 2011 8:54 pm Post subject: BRODIT ITEM 215470 active mount for TomTom 1005 |
I have just received my mount from DSLDevelopments and whilst i am happy with the item it is not BRODIT at all but merely a TomTom item marked TomTom and in a TomTom box.
I have had to wait for these to arrive from Sweden and paid the DSL price when i could have ordered from Tom Tom at a cheaper price and probably recieved it sooner.
Anybody contemplating ordering one just bear this in mind the item is not Brodit although you will need the Brodit Proclip to mount it.
Having had my whinge i must say it is a very good mount and is rock solid. |
Posted: Wed Jan 19, 2011 9:40 pm Post subject: |
One other option is to use the mount supplied with the device but slightly modify it to fit on the Brodit "Ball" there is some additional information in This Thread, I haven't published the Go-1000/ 1005 mount conversion as yet but I can assure you it works in the same way as all the other conversions published to date.
Whilst this is a cheaper way to mount the 1000/ 1005 on to a Brodit Pro-Clip it won't give you the audio line output socket like you get with the true "Brodit mount" from TomTom, but if all you want is a dash mount its a very viable option worth considering - Mike |
JaguarV12e Regular Visitor
Joined: Feb 07, 2005 Posts: 171 Location: Cambridge UK
Posted: Wed Jan 19, 2011 9:51 pm Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
LesP2008 wrote: | i could have ordered from Tom Tom at a cheaper price and probably recieved it sooner. | I ordered one from tt on Dec 30, and it has still not been shipped. _________________ Tomtom Go 1005
Tomtom Go 730T |
Chrisc Occasional Visitor
Joined: 23/10/2002 21:54:26 Posts: 14 Location: United Kingdom
Posted: Thu Jan 20, 2011 12:13 am Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
LesP2008 wrote: | I have just received my mount from DSLDevelopments and whilst i am happy with the item it is not BRODIT at all but merely a TomTom item marked TomTom and in a TomTom box.
I have just received mine from DSL too, it is marked tomtom but it came in a Brodit bag and box! As I see it there are two issues with this mount, the first is there is no way to lock the angle of the ball joint, and the second is that when demounting the unit it moves causing a readjustment every time. This will in time wear the ball and socket and the unit will not stay where you want it.
The USB cable supplied also fouls the pro clip making adjustment in some areas impossible. Definitely not up to the usual Brodit standard.w _________________ TT for IOS
TTG 1005 live
TTG 920 (retired)
TTG 700 (dead)
Kind Regards
ChrisC |
Darren Frequent Visitor
Posted: Thu Jan 20, 2011 1:34 pm Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
LesP2008 wrote: | I have just received my mount from DSLDevelopments and whilst i am happy with the item it is not BRODIT at all but merely a TomTom item marked TomTom and in a TomTom box. |
To clarify, it's a collaboration between Brodit and TomTom. But there does seem to be a huge variation in pricing for this mount with TomTom being very cheap for a change.
I've seen prices as high as £55 on one site, DSL is £43 and TomTom £35 although I think that's a promotional price as it was £40+ last time I checked there.
I've bodged mine as per Mike's tip using a Brodit Ball. It needed some packing to keep it stiff but it works. _________________ Darren Griffin
Posted: Fri Jan 21, 2011 2:15 pm Post subject: |
I too have noticed this. Where my mount for my 930 had a similar swivel it was a much neater unit. the ball system on the new mount does make it stick out a bit but perhaps im lucky mine is rock solid even when dismounting the unit |
Posted: Fri Jan 21, 2011 3:56 pm Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
Chrisc wrote: | I have just received mine from DSL too, it is marked tomtom but it came in a Brodit bag and box! As I see it there are two issues with this mount, the first is there is no way to lock the angle of the ball joint, and the second is that when demounting the unit it moves causing a readjustment every time. This will in time wear the ball and socket and the unit will not stay where you want it.
The USB cable supplied also fouls the pro clip making adjustment in some areas impossible. Definitely not up to the usual Brodit standard.w |
It's an odd one, I'll check with Brodit but I think that Brodit make the ball mount and the plate that affixes to your ProClip and TomTom manufacture the cradle itself. It's certainly not as well thought out as other Brodit solutions but with TomTom insisting on using their proprietary connector, Brodit may have had little choice but to partner.
However, even Brodit's normal adjustable ball joint mounts have no facility to lock them in place, they all rely on friction, but you can adjust it by tightening the screw, something you cannot do with this design here.
Regarding the USB cable, does it exit to the rear of the mount? _________________ Darren Griffin |
Posted: Fri Jan 21, 2011 7:56 pm Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
The USB connector comes out of the rear of the mount. The mount is L shaped and the conector and audio out fit into the junction on the horizontal and vertical.
I must admit I am none too impressed with the quality!
I paid £32 for mine i think via Amazon. _________________ TT for IOS
TTG 1005 live
TTG 920 (retired)
TTG 700 (dead)
Kind Regards
ChrisC
WackyRaces Banned
Joined: Aug 04, 2010 Posts: 172 Location: Banned Member Using New ID
Posted: Fri Jan 21, 2011 9:22 pm Post subject: Re: BRODIT ITEM 215470 active mount for TomTom 1005 |
Darren wrote: | I've seen prices as high as £55 on one site, DSL is £43 and TomTom £35 although I think that's a promotional price as it was £40+ last time I checked there. |
The mount seems to be £32.94 including delivery on the TomTom website but you should get £2.20 cashback (8% on the pre VAT price) a few months later if you start your visit to the TomTom website after first joining up at www.topcashback.co.uk So that takes the net price down to £30.74
It would have been cheaper still if the £8 cashback off items from the TomTom website shop promotion that was running in November and December had been utilised. But I expect TomTom won't have another offer like that for several more months.
I don't know what their justification is for charging more than for the x40/x50 series Brodit clip compatible mount when it actually seems to be more flimsy. I suppose it will mainly come down to this being their newest fixed in car mount. |
Posted: Sun Apr 10, 2011 12:47 pm Post subject: |
mikealder wrote: | I haven't published the Go-1000/ 1005 mount conversion as yet but I can assure you it works in the same way as all the other conversions published to date. |
Here is how to convert the Go-1000 mount to dash mount (Brodit/ Proclip) at minimal cost:
All thats needed is a Brodit Pro-Clip to suit your car and the Brodit "Ball" intended for use with the iPhone car kit, a torx size 5 screwdriver and a small Philips screw driver.
Start by removing the two size 5 Torx screws from the back cover of the Go-1000 mounting shoe:
With both screws removed which can be fiddly as they get held in place due to the magnets but they do come out. Using nothing more than your thumb nails part the two sections of the mount:
With the front cover removed you can also remove the large magnet, this is handy to stop those little screws from rolling around on the table and getting lost!
The rear section of the mount shoe is next to remove, using the small Philips head screwdriver simply release the four screws that hold it in place:
Push the black "collar" back towards the windscreen sucker to reveal access to the translucent ball cover:
Pull the translucent ball cover off the windscreen mount:
Finally pull the black collar off the ball, note this can be a little stiff but will come off with gentle force:
Now you start the process of rebuilding your mount on to the Brodit Ball:
First slide the black collar over the "ball":
Next is the translucent ball cover which is pushed in to place, look at the next photograph before pushing this part in to place:
Take care to make sure the keyway is in the correct position, looking at the picture you can see the small notch in the translucent ball cover at the six o' clock position, if you don't get this notch and key-way correct the mount will be floppy when built up:
Re-fit the rear portion of the mount shoe using the four Philips head screws, these need to be tight:
Fit the main magnet into the front cover before snapping the front portion of the mounting shoe back in position, once secure re-fit the two size 5 Torx screws in the rear of the holder:
Fit the Pro-Clip/ Brodit 1K mount in to your car, and fit the power cable supplied with the device to the mount, note in my installation the power cable is routed out of sight through the airvent which makes for a very neat installation devoid of cables all over the inside of the car:
Finally pop the unit on the mount and away you go:
Mike |
Mr-B Regular Visitor
Posted: Wed Apr 13, 2011 9:21 am Post subject: |
So let me get this right - this is a method of using the Brodit iphone mount 533091 (cost £20) to convert the existing TT suction mount, instead of the Brodit TT100x mount 215470 (cost £44)?
(I couldn't see any mention of Brodit mounts on the TT site.) |
Posted: Wed Apr 13, 2011 9:38 am Post subject: |
Yes but they are quite different. The more expensive mount has line out on its rear and is a one piece mount with dock connector built-in rather than using the two-part mount supplied with the GO 100x.
If you don't need the line out though, then the cheaper solution does much the same in the end. _________________ Darren Griffin |
Posted: Wed Apr 13, 2011 4:49 pm Post subject: |
And don't forget to factor in the cost of a replacement car charger lead if you go with the Full Brodit mount from TomTom with the line-out connector as that needs a mini-USB style car charger, my method avoids the extra cost of the car charger cable by using the cable supplied with the device - Mike |
Posted: Wed Apr 13, 2011 5:33 pm Post subject: |
As I mentioned before I can't find a Brodit mount on the TT site.
However the Brodit 215470 adapter seen on other sites (cheapest I've found is £36) does come with a cigarette lighter charger cable. I'm prolly going for this as it means it's easier to keep the original suction mount intact for use in other cars and the original USB cable for use with the PC. |
IanS100 Frequent Visitor
Posted: Wed Apr 13, 2011 5:35 pm Post subject: |
mikealder wrote: | And don't forget to factor in the cost of a replacement car charger lead if you go with the Full Brodit mount from TomTom with the line-out connector as that needs a mini-USB style car charger, my method avoids the extra cost of the car charger cable by using the cable supplied with the device - Mike |
What kind of power connector does the original TomTom mount use? |
