Pocket GPS World :: View topic - Will sygic work with wince 6 ?
blackstars
PostPosted: Fri Jan 14, 2011 9:18 pm    Post subject: Will sygic work with wince 6 ? Reply with quote
Hi guys, hope you can help,
I have a chinese double din headunit running wince 6, i downloaded sygic mobile maps, windows version, from their own website.
i put all the files on to the sd card and put the card into my device. Everything came up fine and i could select the voices change the date etc, etc. the next stage was to input the product code, so i could access the maps. This is where the problems began.
For some reason, after several attempts, it would not accept the code. so i switched the unit off and then back on again, now all that happens is nothing, when i touch navigation on the screen, nothing happens. i can access setup and select setupwinmobile and that is it.
i emailed sygic, and they said they have reset the code, so i tried again, still no joy. Now they are telling me that it will not run with wince 6. it only runs with windows mobile 6.1 and 6.5. is this correct ? it seemed to be working right up into i tried putting the code in.
it just says on their website, windows mobile, not which versions. The unit runs fine with igo8 and tom tom.
will it work with my unit or should i ask for my money back ?
I am a newbie to in dash sat nav progs !
