lostinuk Lifetime Member
Posted: Mon Nov 08, 2010 10:21 am Post subject: TT GO930- Are these problems related? |
I am the proud ( ) owner of a TTG930 that is about 2 1/2 years old.
For a while now the battery has been goosed, it won't survive more than a couple of minutes not connected to the car charger. I am now considering having a replacement battery fitted at www.satnavrepairservice.com for £24.99.
Also for a while now, even when connected to the car charger (the green light remains on so the unit is charging) the unit crashes and then goes through a reboot process. Sometimes, not always, the reboot loses the current destination and reverts to the previous destination. It can be a bit irksome having to re-enter the current destination.
So my question is, is it likely that replacing the battery will resolve the 'crashing' problem, or is it a separate issue. If so if I will need to restore my TT software I guess, which leads me onto another problem! I have only have a TT backup since the crashing problem has started, so if it is a config issue, a restore will surely only instal the same issues?
Many thanks for any help and guidance!! _________________ Iphone 7 running IOS 11.1.2
CamerAlert
Tom Tom W Europe
Tom Tom US-Canada
Now using Waze as primary GPS. |
Posted: Mon Nov 08, 2010 1:29 pm Post subject: |
You only need the Western_Europe and North American map folders from the backup, all the other data files/ folders can be downloaded for free and installed to the device, to be honest I would consider putting everything on to either an 8GB or 16GB Class 6 SDHC card and put that in the unit rather than use the built in memory which could be showing early signs of failure (crashing/ reboots/ lost destination etc) - Mike |
Posted: Mon Nov 08, 2010 3:11 pm Post subject: |
Mike, many thanks for your prompt response.
Is there an idiot's guide anywhere on how to do this please? _________________ Iphone 7 running IOS 11.1.2
CamerAlert
Tom Tom W Europe
Tom Tom US-Canada
Posted: Mon Nov 08, 2010 4:10 pm Post subject: |
Use Windows Explorer to copy the Western_Europe and North_America map folders to your PC, later tonight I will post up a set of instructions as to what to do to install everything else from scratch, might make it easier if you also locate, download and install a copy of WinRar which is my prefered PC application to expand and install downloads from the TomTom server - Mike |
MrDJ Regular Visitor
Posted: Mon Nov 08, 2010 10:05 pm Post subject: |
im taking your advice and moving everything onto my 8gb sd card as ive had 3 random freeze/crash/reboot and am thinking it could be the internal drive on my referb 4 month old 930. it doesnt like holding a battery charge so always use it connected to ciggy lighter.
sorry to hijack the post but also it wont dim at night with auto dim or manual change it just stays on full brightness.
any ideas gurus of knowledge |
Posted: Wed Nov 10, 2010 7:56 pm Post subject: |
Hi Mike
Appreciate you are busy, but did you get a chance to post up the instructions above? I can't seem to find them, so can you give me a link please?
Many thanks! _________________ Iphone 7 running IOS 11.1.2
CamerAlert
Tom Tom W Europe
Tom Tom US-Canada
Posted: Wed Nov 10, 2010 9:35 pm Post subject: |
Assuming you are using a memory card and a card reader plug it in to the computer and make sure you identify the drive letter associated with the card by viewing Windows Explorer, at this point copy your map folders from the backup to the drive letter associated with the SD card.
Next you need the latest Navcore software for the card, click Here to download the 8,351 version (currently the latest). Once this is saved to the PC use WinRar to extract the files and folders contained in the download to the drive letter associated with the SD card.
Next is a couple of Text To Speech voices, again download from the linked text and store the download on your computer. Use WinRar to extract the files/ folders to the "LoquendoTTS" folder which you will find on the drive letter associated with the SD card:
British Kate Voice
British Simon Voice
For the latest PostCode data click Here and extract the download to the drive letter associated with the SD card.
For the next step use Windows Explorer to create a series of new folders in the root of the SD card, the folders need to be named as follows:
mp3
voices
itn
schemes
text
Finally put the card in to the TomTom and switch it on, connect it to the computer and use Home to download/ install any of the non Text To Speech voices that you need, the ones that came with the device are free to download - Mike |
blazer Occasional Visitor
Posted: Fri Nov 24, 2017 3:02 pm Post subject: |
Many thanks! This info may years old, but this helped bring back Kates voice. Than k you.
mikealder wrote: | Assuming you are using a memory card and a card reader plug it in to the computer and make sure you identify the drive letter associated with the card by viewing Windows Explorer, at this point copy your map folders from the backup to the drive letter associated with the SD card.
British Kate Voice
British Simon Voice
mp3
voices
itn
schemes
text
