Pocket GPS World :: View topic - RDS Receiver packed up on Tomtom 730T
rascall
PostPosted: Sun Jan 24, 2010 6:51 pm    Post subject: RDS Receiver packed up on Tomtom 730T Reply with quote
Hi gents.
Anyone can solve this one. My RDS cable has been working fine recently when out of the blue it stopped yesterday from Essex to Gloucester and the return journey today. It is searching for the signal but has not found anything in a total of 8 hours driving.
Have I touched something I shouldn't have or do you think the wire is broken again? The device is finding the receiver, just not the signal.
Ron (1):
DEVICE: Tomtom Go 730(t)
App: 8.351
MAP: Western & Central Europe v815.2003
GPS V1.21. Boot 5.5120
keithjeffrey
PostPosted: Sun Jan 24, 2010 7:02 pm    Post subject: Reply with quote
I have had a few problems with mine in the past.
Once it was a problem with the wire , where it had pulled out ( somehow ?? ) near the egg shaped receiver 'thingy'.
Another one needed to be plugged into the 730T just right or it would'nt work ( that one went in the bin pretty quickly ).
Just the other day my one was searching for well over an hour , so I pressed the reset in the bottom of the 730T and restarted it and it worked fine after that.
Worth giving the reset a go.
Keith
TomTom GO 730T App 8.392 (1909/091109) , W and CE 2GB v835.2419
Gee-Pee
PostPosted: Sun Jan 24, 2010 8:03 pm    Post subject: Reply with quote
Are you using the egg shaped aerial receiver?
I have noticed that, although mine does work very well most of the time, it seems to be that, as long as I start it from home or from the last location when it was operating , then it works fine. If, however, (say) I don't use it on an outward journey, then connect it for the return, it takes a lot longer to connect. That may be only in my mind. Make sure you have it connected and a route planned before you set off and see if it makes any difference.
Non-technical reply Rolling Eyes
Graham
Gee-Pee
PostPosted: Sun Jan 24, 2010 8:12 pm    Post subject: Reply with quote
The last RDS-TMC reception radio frequency employed is stored within the PND device which goes some way to explain why it works better if switched on/ powered up in the same location last used rather than moving it 100+ miles - Mike
rascall
PostPosted: Sun Jan 24, 2010 8:18 pm    Post subject: Thanks but still not working Reply with quote
Thanks for the replies gents. I am back at home now (Essex) and still not receiving. I have reset and still nothing. I have had a peep at which frequency it is set to. It is reporting 88.0. Does that sound right?
Ron (1):
App: 8.351
AndyVaughan
PostPosted: Sun Jan 24, 2010 8:22 pm    Post subject: Reply with quote
What frequency is Classic FM broadcast on near you?
Try manually setting it to that frequency.
Gee-Pee
PostPosted: Sun Jan 24, 2010 9:03 pm    Post subject: Reply with quote
I think it is the same as mine (SW Essex) which is between 100.00 & 102.00 - I get it on 100.6 but see
HERE
Graham
Gee-Pee
keithjeffrey
PostPosted: Sun Jan 24, 2010 9:13 pm    Post subject: Reply with quote
I have emailed Ron the .ov2 and .bmp for the TMC POI to put on his 730T , so that he can tune in manually from that.
Keith
rascall
PostPosted: Sun Jan 24, 2010 9:17 pm    Post subject: Thanks again but still no go Reply with quote
Gee-Pee, I have entered the frequency manually and it's back to the searching mode still. I think it must be the wire.
Ron (1):
App: 8.351
rascall
PostPosted: Sun Jan 24, 2010 9:18 pm    Post subject: Thanks Reply with quote
Thanks Keith for the file. I have downloaded it onto the device. This is a very handy working tool. Ron
Ron (1):
App: 8.351
