Pocket GPS World :: View topic - Camera Manager Login Problems
Pipeliner
PostPosted: Fri Jan 01, 2010 12:50 pm    Post subject: Camera Manager Login Problems Reply with quote
When using Camera Manager on my home pc using Windows XP all working fine. When using Vista on laptop, CM cannot see that I am logged into website. Now upgraded to Windows 7 at home and now have the same problem. Checked firewall and turned off and on Compatability View in IE8, refreshed screen using Ctl+F5, all to no avail. Would be greatful for some help before the next camera database update. Oh, happy new year to all.
Regards
PaulB2005
PostPosted: Fri Jan 01, 2010 1:08 pm    Post subject: Reply with quote
A quick search brings up this thread
mediaguycouk
PostPosted: Thu Jan 07, 2010 11:38 pm    Post subject: Reply with quote
Windows 7 protected mode stops applications from piggybacking on IE to talk to the internet.
Go to pocketgpsworld.com in Internet Explorer 8
If you can see the status bar double click 'Internet | Protected Mode :On
(If you can't see the status bar go to Tool - Internet Settings - Security)
Click on Trusted
Click on Sites
The address should be pre-filled in the add field (if not add http://www.pocketgpsworld.com )
Untick Require Server Authentication
OK out of all options
Camera Manager will now be allowed to use IE to download the files.
I did tell Ash10 this when beta testing the report but I don't know if anything was done (as he'd have to integrate the web browser into the program to get around this, easy in C# but I don't know what language he is using)
(As a site note, are you serious PGPSW that you can't use a triangular bracket *at all* in a post?!?)
PaulB2005
PostPosted: Fri Jan 08, 2010 10:03 am    Post subject: Reply with quote
It's more to do with the board software being used than a decision by PGPSW. Something to do with HTML code i suspect....
PostPosted: Fri Jan 08, 2010 11:46 am    Post subject: Reply with quote
the easiest way to stop malicious html code being posted in the forums is simply to block the < and > symbols. it works!
22.105 (30 Oct 24)
