snowyjp Occasional Visitor
Posted: Sat Dec 19, 2009 12:08 am Post subject: voice alerts (IGO 2006) |
Hello
can any one tell me how to down load Aus/Nz consolidated sound file to my iGO unit
snowyjp |
Andy_P Pocket GPS Moderator
Posted: Sat Dec 19, 2009 2:48 am Post subject: Re: voice alerts |
snowyjp wrote: | Hello
can any one tell me how to down load Aus/Nz consolidated sound file |
Is there such a thing? I don't know of any sound files for any of the camera databases except for the UK and Europe.
Can you say where you've seen it?
I'm not sure if voice alerts work on the iGo either....
As M8TJT said after sorting out your camera problems in your other topic
M8TJT wrote: | Well Snowy, that's a result then. I told you not to give up
I don't think Igo have ever done voice warnings for speedcams . |
M8TJT The Other Tired Old Man
Posted: Sat Dec 19, 2009 9:46 am Post subject: |
Speed cam voice alerts do not come with a standard IGO installation. You have to load and enable a skin (Display interface) that supports them and the voice files themselves. Try Googling for IGO 1006 skins. Installing them is a bit more difficult than the PGPSW database. I know what your problem is, you are fed up with the 'turkey gobble' alert. The default sound mentioned abov is 'Alert5' which you could edit or load a different sound as Alert5 to quieten it down a bit.
Dont forget to make a full Windows backup of your device or SD card before you start. |
Posted: Sun Dec 20, 2009 7:23 am Post subject: Voice alerts |
Hello again wow my mind bogles
I think to much for this 70yo brain
I have got all the voice files in wav format
they are in the uk locations
is it possible to convert these files to aus so they activate at my speed camera locations
Its a thought
Snowyjp |
Posted: Sun Dec 20, 2009 7:30 pm Post subject: Re: Voice alerts |
can any one tell me how to down load Aus/Nz consolidated sound file to my iGO unit |
Not quite certain what you mean by 'Aus/Nz consolidated sound file'
and also snowyjp wrote: | I have got all the voice files in wav format they are in the uk locations |
It is not possible to just put the voice files on the IGO and have it work. You also HAVE to put a 'Skin' that supports voice files onto it as well to use them. I suspect that you will need someone who is realy a PC black belt to help you do this. |
Posted: Sun Dec 20, 2009 8:54 pm Post subject: voice alerts |
OK mate
i will have to put up with just the beeps
maybe there is voice files on the net somewhere
Have a great xmas
you have been great
Regards
Snowyjp |
Posted: Tue Dec 22, 2009 11:27 pm Post subject: voice alerts |
hello again
i now have a skin for voice files it is Ultra Skin v2.6
i down loaded it direct to iGO folder but when i tried to open the GPS i got a message Error( ffui error) so i had to delete it and go back to factory settings
do u have any ideas how to install it i have not got any instructions
the sound files have an ogg ext
snowy |
Posted: Wed Dec 23, 2009 9:01 am Post subject: |
It is probable that the skin that you have tried is not for IGO 2006. I believe that linknet's Ultra skin is for the latest versions of IGO. It won't work with IGO 2006. You need a skin that has been designed for 2006. Try Googling for igo 2006 skins, but I don't think it will be easy to find one, unless linknet is lurking and knows the answer. Linknet's latest skin for IGO 8.3 does not support voice alerts anyway. |
Posted: Fri Jan 01, 2010 11:38 am Post subject: voice alerts |
HI mate
I found a skin that supports iGO2006
The prob is i cannot find the skin folder in the content so i made a new folder and downloaded the skin there but did not work is there a way to open the skin folder that is in the menu
also i need to have the correct resolutions but cant find how to change them
can u help me there
Snowy |
Posted: Fri Jan 01, 2010 4:46 pm Post subject: |
As I said before, I am not familliar with 2006, but in IGO8 there is a menu item Menu ~ Settings ~ {More. Right arrow} ~ Menu ~ Skin. From where you can select the skin. If not then I hope that a 2006 expert will junp in and suggest a way of doing it. |
