Pocket GPS World :: View topic - 720 moving (downwards) on mount - viscosity?
mightyyid
PostPosted: Sun Sep 27, 2009 12:08 am    Post subject: 720 moving (downwards) on mount - viscosity? Reply with quote
Chaps
Not sure how to term this so hoping the title will say it all - my 720 mount has for a while been 'loose' and by that I mean that after about 10 minutes on the mount, the weight of the TT will actually cause the joint to move, thus succumbing to the forces of gravity, so the unit ends up pointing more downwards than into the car. So, the viscosity of the ball joint on the mount is not strong enough to support the weight of the unit.
Anyone any bright tips on how to resolve this before I try. My thoughts will be sticking it in a freezer for a while and maybe one or two other things. No point in buying a new mount as it's not that worrying, but just wondered if there are any tricks. Or indeed if there is a better way to explain it as I'm struggling with this one...
Andy
AliOnHols
PostPosted: Sun Sep 27, 2009 8:18 am    Post subject: Reply with quote
Hi mightyyid, I get this also and find that theTT's droop gets quicker as the temperature rises. Not very technical but my "Bodge" is to wedge a bit of something (normally paper or cloth, folded over several times) between it and the dash-board. This has the added advantage of also taking the weight of the unit and stops the suction to the windscreen failing as often as it normally does and If I use a bit of black cloth, it stops a lot of the reflection in the TT screen.
Garmin Nuvi 2599
SatMap Active 10 & 20.
mightyyid
PostPosted: Sun Sep 27, 2009 9:10 am    Post subject: Reply with quote
Thanks - hot climates do not seem to help. I'm going to try a few things such as sticking it in the freezer overnight and seeing what happens...
Will advise if anythng does...
PostPosted: Sun Sep 27, 2009 9:21 am    Post subject: Reply with quote
Have a look at the TomTom web site, they make a new type of mount for the x20/ x30 devices known as the "Easy Port" it might be worth considering changing to one of these, I would also talk to Customer Support as the mount shouldn't be going soft in this way - Mike
Trevor1234
PostPosted: Sun Sep 27, 2009 11:17 am    Post subject: Reply with quote
Hi mightyyid
I purchased an alternative mount for my 720 shortly after getting my device. The original mount has only been used twice. If you let me have your address I will pop the original into a jiffy bag and post it to you. No charge. It will be my good deed for the year.
Tomtom Go 720.
Navcore 9.510
GPS World Traffic cameras
Home 2.7
iPhone 3G
Robbo66
PostPosted: Sun Sep 27, 2009 9:27 pm    Post subject: Reply with quote
What, all the way to Melbourne Trevor?
That really is the action of a true samaritan. Good on yer!
TT 720 Go
Application version 8.351
WE Map version 855.2884
4Gb SDHC card
Trevor1234
PostPosted: Sun Sep 27, 2009 10:07 pm    Post subject: Reply with quote
Hi Robbo66
B----y hell, I dropped a bit of a clanger there.
Hi mightyyid, the offer is off. Sorry.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
mightyyid
PostPosted: Mon Sep 28, 2009 4:53 am    Post subject: Reply with quote
Hi Robbo66
Well, that is just rude.
Not a problem and many thanks for the offer. It's certainly not worth it, but you can send it to my parents in the UK!
More so, I suspect this must be happening to other units so I am hoping for a quick fix that sorts this and will keep trying. Freezer the first attempt - to be tried tonight.
Cheers again fella...
AliOnHols
PostPosted: Mon Sep 28, 2009 5:59 am    Post subject: Reply with quote
I took mikealder's advice and e-mailed TomTom Support with my "Challenge". I shall let you know of any progress.
Garmin Nuvi 2599
mightyyid
PostPosted: Mon Sep 28, 2009 7:24 am    Post subject: Reply with quote
Thanks - let me know how it goes as I'd be interested if they care enough to worry about it. It's one of those annoying things that you want to chnage but at no cost...
Trevor1234
PostPosted: Mon Sep 28, 2009 9:50 am    Post subject: Reply with quote
Hi mightyyid
If you leave your parents address in my messages I will post the mount to them. It may come in handy for you and it will leave me looking a less of a Scrooge than it first appeared.
Ba! Humbug.
Tomtom Go 720.
Navcore 9.510
Home 2.7
iPhone 3G
AliOnHols
PostPosted: Tue Sep 29, 2009 6:28 am    Post subject: Reply with quote
mightyyid wrote:
....let me know how it goes ...
I recieved an e-mail from TTSupport yesterday (10/10 for the very quick & positive response) asking to see proof of purchase. I shall send that off to them today and see what happens.
Garmin Nuvi 2599
mightyyid
PostPosted: Wed Sep 30, 2009 11:17 pm    Post subject: Reply with quote
Thanks for that. being in Australia makes things harder but having looked at my mount now, and not sure why I have not noticed this before, but it actually has to small chunks out of the plastic where the ball joint is. Given the location it's not as if dropping could do it, and it's fairly thick plastic so I suspect it could be due to heat or something - after all, what does the mount do other than stick to the window.
Anyhow, I tried the freezer trick. Some trick - held it in place for a while until the temp rose and then dropped again.
So I'll get another one from somewhere and get it sorted. I suspect TT will not case given the age of my 720 and with the chunks missing have a perfect get out clause.
psyskiesman
PostPosted: Fri Oct 02, 2009 4:00 pm    Post subject: Reply with quote
My 720 mount disintegrated in the same way. Started as small hairline cracks and then chunks of plastic missing; I contacted TomTom and they asked me to attch a copy of my purchase receipt to an email. They sent me a new mount by return. Could be worth atry, espacially if your receipt, like mine, is very feint. I doubt if they could have read the purchase date.
PostPosted: Fri Oct 02, 2009 7:20 pm    Post subject: Reply with quote
Same thing happened to mine.
I sent them these pics and they sent a replacement, no questions asked.
22.062 (12 Jun 24)
