Pocket GPS World :: View topic - Tom Tom Error Messages
Goto page 1, 2, 3  Next
mnealio
PostPosted: Fri Sep 18, 2009 10:39 pm    Post subject: Tom Tom Error Messages Reply with quote
please bare with me because i'm new to this, i've had my Tom Tom One since it first came out and hadno problems with it..............
Now since i have downloaded Tom Tom Home 2.6 when it loads up i get this error message
Component returned failure code: 0x80570015
and a lot of other codes but it will not let me copy and paste it on here for some reason............
hoping someone can help
now i havn't a clue what to do.......... can someone please help?
PaulB2005
PostPosted: Sat Sep 19, 2009 12:47 am    Post subject: Reply with quote
Remove all the "greater than" (or "less than") symbols. .i.e the straight line brackets. Then try reposting the error here.
dhn
PostPosted: Sat Sep 19, 2009 3:30 am    Post subject: Reply with quote
Are you using Firefox as the browser?
mnealio
PostPosted: Sat Sep 19, 2009 5:10 pm    Post subject: Reply with quote
i'm using internet explorer
here is the code i get
ERROR: Exception... "Component returned failure code: 0x80570015 (NS_ERROR_XPC_CI_RETURNED_FAILURE) nsIJSCID.createInstance" nsresult: "0x80570015 (NS_ERROR_XPC_CI_RETURNED_FAILURE)" location: "JS frame :: chrome://tthome/content/logic/comm.js :: anonymous :: line 266" data: no
in chrome://tthome/content/logic/comm.js:266
Stack:
0. chrome://tthome/content/logic/comm.js:266
this.request = new XMLHttpRequest();
1. function rpcCall chrome://tthome/content/logic/comm.js:180
this.setup();
2. chrome://tthome/content/logic/comm.js:53
errorCallback);
3. chrome://tthome/content/logic/comm.js:128
errorCallback));
4. chrome://tthome/content/ui/mainwin/bannerManager.js:89
unimportantError);
5. chrome://tthome/content/ui/mainwin/bannerManager.js:30
this.fetch();
6. chrome://tthome/content/ui/mainwin/mainWin.js:72
this.bannerManager.start();
7. function onLoad chrome://tthome/content/ui/mainwin/mainWin.js:15
gMainWindow.start();
8. function onload chrome://tthome/content/ui/mainwin/mainWin.xul:1
?xml version="1.0"?
Time: Sat, 19 Sep 2009 16:08:31 GMT
dhn
PostPosted: Sat Sep 19, 2009 5:48 pm    Post subject: Reply with quote
You could try uninstalling 2.6 from the computer (using Add/Remove programs) and getting the latest application (2.7) from TT's site and try installing that.
Use this link
rjbsec
PostPosted: Sat Sep 19, 2009 5:53 pm    Post subject: Reply with quote
Uninstall/reinstall will encounter problems unless the 'old' file is re-named e.g. Home_old.
mnealio
PostPosted: Sat Sep 19, 2009 11:00 pm    Post subject: Reply with quote
hi, thanks for that info but how do i do that? i havn't uninstalled anything yet and will not do until i hear back
rjbsec
PostPosted: Sun Sep 20, 2009 7:44 am    Post subject: Reply with quote
When you uninstall Home it will still leave a file on your 'C' Drive "Tom Tom Home 2" or similar - if you leave it you will experence problems with the re-install.
So having uninstalled the old programme, go to Start / My Computer / C Drive / Program Files and search for the old Tom Tom file, e.g. 'Tom Tom Home 2' - right click on the file and select 'Rename' then change it to anything you want e.g. 'Home_old'.
Having done that, install the new Home programme.
After installation you can go back into Program Files and delete the file you renamed as 'Home-old'.
That is the response from Tom Tom Support that worked for me.
mnealio
PostPosted: Sun Sep 20, 2009 12:46 pm    Post subject: Reply with quote
Hi thanks,
I did that and when i installed 2.7 and it opened i just all a load of error messages again
at my wits end Laughing Out Loud
rjbsec
PostPosted: Sun Sep 20, 2009 1:46 pm    Post subject: Reply with quote
mnealio wrote:
Hi thanks,
Oh dear - don't you just hate computers!
Can you take your PC back to the state it was in before you downloaded Home 2.6 on Friday?
Start / Help & Support / Tools / System Restore
Find the point where you downloaded Home (or as near as possible before) and select the option to restore you PC to then (it will return your settings etc to what they were before you downloaded - you won't lose any emails etc but it will affect any NEW programmes installed since that time).
Once it has completed the restore (it will need to restart you PC .. don't panic!) do what I outlined above AGAIN, i.e. uninstall the old Home (which should now be back to how it was before you updated) and then change the name of the file that is left over in Program Files after the uninstall.
So you should now have uninstalled Tom Tom Home and changed the name of the Tom Tom file in Program Files.
Now go to the Tom Tom website and download and install Home 2.7 - hopefully it will work successfully this time.
dhn
PostPosted: Sun Sep 20, 2009 1:49 pm    Post subject: Reply with quote
That's another thought......
Have you rebooted the computer between the 2.6 uninstall and the 2.7 install? If not do a reboot now and try connecting the unit to Home again.
mnealio
PostPosted: Sun Sep 20, 2009 3:18 pm    Post subject: Reply with quote
gonna do a system restore now will let you's know how i get on
rjbsec
PostPosted: Mon Sep 21, 2009 3:27 pm    Post subject: Reply with quote
Long time, no hear - hope nothing worse happened Sad
mnealio
PostPosted: Mon Sep 21, 2009 11:03 pm    Post subject: Reply with quote
when i did the system restore i still had the version 2.6 and when i renamed it, and installed the 2.7 i still got all the error messages, so now i have removed all tom tom applications from my computer........ i know if i download it again the same thing will happen.
rjbsec
PostPosted: Tue Sep 22, 2009 7:50 am    Post subject: Reply with quote
That is weird, I had issues but as soon as I did the uninstall, re-name and re-install my problems went away. Obviously something is causing a conflict on your PC, sometimes anti-virus programmes can do this; on one of my laptops I had Avast A/V installed and it would regularly cause the laptop to crash - had to remove it and now all is well.
There is a piece of free software that I use regularly called CCCleaner that removes all 'rubbish' left on a PC, including in the registry - you could do the restore again, then run CCCleaner and try again but beyond that I'm afraid that I don't have any further suggestions.
Edit
You didn't say you uninstalled 2.6 after the restore - did you miss that step
Page 1 of 3
