ratman633 Lifetime Member
Posted: Tue Aug 25, 2009 10:45 pm Post subject: |
[quote="AndyVaughan"]Have you tried replacing the tmccodes.dat and traffic.dat files?
I've just had a look at these files in the new map and they were both 0kb in size. Copied them over from the backup I made before updating the map and HD traffic is now working!
Thanks very much for the advice.
I can't believe that TomTom have been unable to come up with the answer. Once again thanks for the help. _________________ Keith
TomTom 540
v9.510
Map v905.4754 |
Posted: Wed Aug 26, 2009 7:02 am Post subject: |
Seamaster wrote: | mcwarre wrote: | Has anyone sorted out the issue with TomTom Live HD Traffic yet ![Question](modules/Forums/images/smiles/icon_question.gif) |
No, and the latest from Tomtom is an obviously cut-and-pasted email with instructions for fixing ""getting stuck on the voice selection", which is a problem I do not have!! ![Rolling Eyes](modules/Forums/images/smiles/icon_rolleyes.gif) |
Try AndyVaughan's suggestion it worked for my 540. _________________ Keith
TomTom 540
v9.510
Map v905.4754 |
AndyVaughan Lifetime Member
![](modules/Forums/images/avatars/gallery/avatar_matrix_014.jpg)
Joined: Apr 13, 2006 Posts: 1500 Location: Rossendale
Posted: Wed Aug 26, 2009 8:26 am Post subject: |
Another satisfied customer!
I am concerned that people are using the tmccodes.dat and traffic.dat files from backups - potentially they could be different if they are from a different map version.
The safest route would be to extract the two files from your new map download just in case. |
Seamaster Frequent Visitor
![](modules/Forums/images/avatars/10783647724cdfa901d5ea9.jpg)
Posted: Wed Aug 26, 2009 8:56 am Post subject: |
Andy, you'll have to indulge me with an idiot's guide to this procedure. I can find the latest map as a .zip file on my Mac, but I can't unzip it for some reason? |
wjv Occasional Visitor
Joined: Aug 25, 2009 Posts: 11 Location: Leipzig, Germany
Posted: Wed Aug 26, 2009 9:05 am Post subject: |
Seamaster wrote: | I can find the latest map as a .zip file on my Mac, but I can't unzip it for some reason? |
For whatever reason, the default Archive Utility on OS X (the thing that runs when you click on a zip file) doesn't want to extract the map archive.
You have several options, though.
You can just open a Terminal and go to the directory where the downloaded map is located, and then use the "unzip" command on the command line to extract the archive.
Or, you can get yourself a 3rd party tool to extract .zip and other archive files. The one that I use is called The Unarchiver, and it's quite powerful (and free):
http://wakaba.c3.cx/s/apps/unarchiver.html |
AlanH Occasional Visitor
Posted: Wed Aug 26, 2009 9:13 am Post subject: |
I have a similar problem with unzipping the speed camera database on my Mac. I find StuffIt Expander does the job. |
Posted: Wed Aug 26, 2009 9:18 am Post subject: |
Thanks, wjv, I've downloaded that and am giving it a go now... |
Posted: Wed Aug 26, 2009 9:19 am Post subject: |
NotAliOnHols wrote: | Personally, I would suggest removing the FuelStationsEU files and store them safely somewhere on your computer (NOT anywhere near your existing TT files though) and see what happens. |
Well, that wasn't it. :(
I tried removing the files (after making a backup, of course), and I still get duplicate (and triplicate) Petrol Stations.
A poster on another forum claims that he "solved" the issue by replacing his poi.dat file with one from a backup made before he updated his map.
Of course, I'd prefer not to do that! Having duplicated POIs isn't really a show-stopper, so I'll just report the problem to TomTom and live with it for now.
I am left wondering whether anyone else has the same issue, though…? |
Posted: Wed Aug 26, 2009 9:30 am Post subject: |
ratman633 wrote: | AndyVaughan wrote: | Have you tried replacing the tmccodes.dat and traffic.dat files? |
I've just had a look at these files in the new map and they were both 0kb in size. Copied them over from the backup I made before updating the map and HD traffic is now working! Thanks very much for the advice. |
Well maybe this isn't the same problem for me. I have unzipped the latest map, and found traffic.dat to be 4K and tmccodes.dat to be 6.4MB.
Am I supposed to copy the older versions of the files from the last map or backup over? And do I have to re-zip it?
Sorry if I'm being a bit thick here. Any chance of a step-by-step instruction for this fix? |
I've just arrived at work and whilst HD traffic is working the touch screen, calculating of route etc is very, very slow. I only changed the tmccodes.dat and traffic.dat files(From a backup) I guess these must be the cause. I would agree with AndyVaughan's point, I'll copy them over from the new map when I get home tonight.
Thanks again _________________ Keith
TomTom 540
v9.510
Map v905.4754 |
Posted: Wed Aug 26, 2009 9:37 am Post subject: |
Seamaster wrote: | I have unzipped the latest map, and found traffic.dat to be 4K and tmccodes.dat to be 6.4MB. |
That sounds about right.
Quote: | Am I supposed to copy the older versions of the files from the last map or backup over? And do I have to re-zip it? |
Nonono, you take the two files that you've just extracted from the .zip, and copy them to the map directory on your device. The end.
In other words, instead of taking the old versions of those two files from a backup and copying them onto your device, just copy the new ones that came in the new map's .zip.
(There are the ones that are presumably supposed to be installed with the new map. Why they end up as being zero-length after going through the by-the-book update procedure is anyone's guess.)
Quote: | Any chance of a step-by-step instruction for this fix? |
I hope the above explains things a little better. If it's still confusing, I'll happily do a step-by-step! :) |
Robbo66 Occasional Visitor
Posted: Wed Aug 26, 2009 10:03 am Post subject: |
Sorry if this has deviated from the main topic but thanks to all for the suggestions re "entering quotes"
Only problem now is choosing which one to use!
Rob _________________ TT 720 Go
Application version 8.351
WE Map version 855.2884
4Gb SDHC card |
Posted: Wed Aug 26, 2009 10:04 am Post subject: |
Thanks, wjv, that's just what I needed to understand, and the fix has (apparently) worked perfectly! ![Cool](modules/Forums/images/smiles/icon_cool.gif) |
AliOnHols Pocket GPS Verifier
![](modules/Forums/images/avatars/21465796014c9af163c058d.jpg)
Posted: Wed Aug 26, 2009 11:03 am Post subject: |
wjv wrote: | ....
Well, that wasn't it. .... |
Sorry it didn't fix it for you wjv. Hopefully somebody else has a better suggestion soon. _________________ Garmin Nuvi 2599
SatMap Active 10 & 20. |
mcwarre Regular Visitor
Posted: Wed Aug 26, 2009 12:18 pm Post subject: |
Sorry if this has been covered but can't be bothered going through 12 pages to find out! |
Andy,
Thanks very much all sorted now! ![Very Happy](modules/Forums/images/smiles/icon_biggrin.gif) |
