Pocket GPS World :: View topic - Car power / Charger For VPx
Leigh_at_ch9
PostPosted: Wed Jul 01, 2009 3:02 pm    Post subject: Car power / Charger For VPx Reply with quote
Guys,
Can anyone (Mike, are you there? hellllllp) point me in the direction of an (ebay style) in-car power / charger cable for my Vodafone VPx?
So far I can only find items from mainstream suppliers which are ludicrously expensive. I thought a cable for an O2 XDA IIs (plentiful) would be the same, but I'm told it's not compatible and I must admit the plug at the device end does look different in pics. Maybe one of the universal ones would be ok but I'm not sure about voltages etc.
I could also do with a cable to plug into the AUX input on my car stereo to make the satnav voice commands louder if anyone has any ideas on that one.
Thanks guys
Leigh
PostPosted: Wed Jul 01, 2009 3:07 pm    Post subject: Reply with quote
The VPx is also known as a QTek 9090. Plenty of chargers on eBay if you search for the QTEK, e.g. this one.
If the QTEK/VPx only has a headphone out then you'd need a suitable cable with a 2.5mm plug on one end for the VPx and a matching plug for your Aux-In. Again fairly commeon see here.
Leigh_at_ch9
PostPosted: Wed Jul 01, 2009 3:14 pm    Post subject: Reply with quote
Yo Darren
Thanx v much for that. One slight concern, afaik the VPx is also supposedly the same as the O2 XDA, but it looks like the input sockets are different. Do u know that a QTEK is the exact same unit? In the meantime I'll check it out and see how far I get
Thx
Leigh
PostPosted: Wed Jul 01, 2009 3:24 pm    Post subject: Reply with quote
Ah hang on, my error there. The VPx is the same as a QTEX 9090 but there are many O2 XDA variants.
The O2 model that is the same is the O2 XDA IIs, see here.
Apologies for adding to the confusion!
PostPosted: Wed Jul 01, 2009 5:28 pm    Post subject: Reply with quote
For a car charger cable for your IIs have a look at This for the audio cable you need a 2,5MM jack plug to whatever is fitted to the Aux input on the Car Stereo, if you experiance interference on the audio that varies with the engine RPM fit a Ground Loop Issolater between the IIs and car deck - Mike
Leigh_at_ch9
PostPosted: Wed Jul 01, 2009 5:31 pm    Post subject: Reply with quote
Hi Darren
You didn't add to the confusion, that's what u said originally, what i meant was that I've been told by ebay shops that the XDA IIs cable is not compatible with the VPx. I think it should be but they say otherwise (maybe they don't know and are playin' safe). Anyway, I bought a charger & cable so all sorted. Thx v much for your input
Leigh
Leigh_at_ch9
PostPosted: Fri Jul 03, 2009 12:45 pm    Post subject: Reply with quote
Darren / Mike
Thanx for the input gentlemen, I've now bought both items
Leigh
