Pocket GPS World :: View topic - mp3s on CD
mp3s on CD
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area
Calomax
PostPosted: Tue Jun 02, 2009 8:58 am    Post subject: mp3s on CD Reply with quote
I haven't been able to find an answer on Google and I hope someone here might be able to help.
I've just changed my car and it has a CD player that can play mp3s from a CD. There is no information about this in the manual. So does anyone know if you just copy the mp3 tracks onto a blank CD and it will play, or do they have to have to be saved in any special way please?
TT Go Essential
PostPosted: Tue Jun 02, 2009 9:59 am    Post subject: Reply with quote
it depends ont eh software used in teh cd player!
sometimes all tracks have to be in the 'root' (ie not in any folders), sometimes you can put tracks into folders (i.e. albums) and sometimes you can even use .m3u playlists... totally depends on the stereo!
have a play with a few different methods!
Calomax
PostPosted: Tue Jun 02, 2009 10:03 am    Post subject: Reply with quote
Thanks MaFt, I'll try copying some onto a CD and see if they play. My Radio instruction book does say something about being able to find folders so that's what I'll try first.
TT Go Essential
richard345
PostPosted: Tue Jun 02, 2009 12:02 pm    Post subject: Reply with quote
My Astra also has an mp3 compatible CD player. I can use iTunes to select a Playlist from the large number of tracks I have available, or I can just rip an Audio CD to a blanck one using Nero or even Windows Media Player.
The tracks can be organised in folders or just on the root and the id3 tag information can actually scroll the Artist and Track name across the display of the car player.
I think there is a limit of 4 ot 5 'nested' folders, beyond which it will not play, but i think that's all.
By 'nested' folders I mean, for example:
Disk 1
Folder 1
Folder 2
Sub-Folder 2.1
Folder 3
Folder 4
Sub-Folder 4.1
Sub-Folder 4.1.1
Sub-Folder 4.1.1.1
Sub-Folder 4.1.1.2
Folder 5
etc.
The above does not seem to diplay correctly in the Preview - Tabs or multiple spaces don't appear, but I think you will see what I am trying to show.
Ric - TomTom 520 DEAD - Passed to the great traffic jam in the sky. Now using Maps & Waze on Samsung Galaxy S4 + CamerAlert of course!
Calomax
PostPosted: Tue Jun 02, 2009 12:09 pm    Post subject: Reply with quote
Thanks Ric, I thought if I used iTunes, I would have to burn them as audio files. Someone on another forum says I have to make sure they are copied as data files not audio files. I'm going to try it tonight.
Mine are saved in Folders by Artist, then Subfolders by Album, so only 2 levels. Anyway it's only a blank CD wasted if I do it wrong.
TT Go Essential
Mullet
PostPosted: Tue Jun 02, 2009 4:33 pm    Post subject: Reply with quote
What they should have said was make sure you create a data disc and not an audio disc.
Because burning software would convert to files to .cda audio instead of leaving them as mp3.
Take the time to tag the tracks properly, or you will have dozens of "track 1", "track 2" etc. It will also take no more effort to add cover art when doing so.
Nero would be ideal, as you may need to relax the filing system to accommodate the long file names, particularly in nested folders
PaulB2005
PostPosted: Tue Jun 02, 2009 5:16 pm    Post subject: Reply with quote
In iTunes make a play-list with your tracks, click Burn CD at the bottom right of the screen.
Then make sure on the selection box you pick MP3 CD, then click Burn.
Calomax
PostPosted: Tue Jun 02, 2009 7:18 pm    Post subject: Reply with quote
Thanks everybody, it sounds as though PaulB2005's method is the easiest so I'll give it a try.
TT Go Essential
Calomax
PostPosted: Tue Jun 02, 2009 9:26 pm    Post subject: Reply with quote
Thanks Paul, that went fine. I'd never burned a CD and hadn't realised that there was an mp3 CD option.
TT Go Essential
Calomax
PostPosted: Mon Jun 15, 2009 8:42 am    Post subject: Reply with quote
I niow have another query if anyone can help please. Once I have burned some mp3s onto a CD, can I add some more later, or does the disc get closed off and can't be written to again please?
TT Go Essential
PaulB2005
PostPosted: Mon Jun 15, 2009 8:56 am    Post subject: Reply with quote
Well as it is a form of data disc you should be ok to add it. However i've had the occassional problem doing so in the past and prefer to use a new disc each time.
Calomax
PostPosted: Mon Jun 15, 2009 9:00 am    Post subject: Reply with quote
Thanks Paul, I guess with the cost of discs these days I'd be just as well to make a new one.
TT Go Essential
PaulB2005
PostPosted: Mon Jun 15, 2009 9:05 am    Post subject: Reply with quote
Try it and see what happens.
I've found using a CD or DVD for data and then adding to it, occassionally it suffers a problem where it looses some of the files that where added earlier. Perhaps it was just poor media or it's one of those pit falls.
Another alternative is to buy 1 or 2 CD RW discs and use those. I often listen to podcasts in the car by using iTunes to burn it to a CDRW (as an Audio CD). Each week i format the disc and use it again.
Calomax
PostPosted: Mon Jun 15, 2009 9:09 am    Post subject: Reply with quote
Thanks again Paul, I'll give that a try. I hadn't bothered because someone on another forum said the CD players in cars don't read rewriteables very well. But if they're successful for you I'll try it.
TT Go Essential
PaulB2005
PostPosted: Mon Jun 15, 2009 9:17 am    Post subject: Reply with quote
I'm using a really old Phillips CD-RW. I just buy a new one when it gets knackered and won't burn any more (6 - 18 months). Whilst more expensive than CD-R singly, if you can get CD-RW to work then it would be cheaper in the long run. Just buy a couple but stick to decent known bands (Sony, Memorex etc etc)
Don't forget to format the disc each time in something like Nero before burning again with iTunes as iTunes has no facility to format CD-RW..
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Lost Satellite Fix - Off Topic Area All times are GMT + 1 Hour
