Pocket GPS World :: View topic - Talex Lite Data Cable Pin out needed
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems
pacemaker1000
PostPosted: Sun May 10, 2009 8:52 pm    Post subject: Talex Lite Data Cable Pin out needed Reply with quote
anybody got the pin out diagram or care to work it out for me?
there are a lot of these kicking around like mine and with the free data base on novus i am keen to use it, should be easy to make
also ill be ready for when th gpsw list works
thanks
talexuser
PostPosted: Sun May 17, 2009 12:26 am    Post subject: Reply with quote
it's not just a question of pinout, the lead contains a serial to usb chip embedded in the plug.
pacemaker1000
PostPosted: Mon May 18, 2009 5:28 pm    Post subject: Reply with quote
thanks
can you confirm, if i get a cable' i can use the free updates for the novus, untill the gps one becomes available Wink
talexuser
PostPosted: Mon May 18, 2009 9:32 pm    Post subject: Reply with quote
Hi, yes, the Novus delta update loads into the old talex lite, and in fact gives you more functions than the talex update - bearing in degrees and height above sea level when moving, trip distance, average speed, max speed, no of satellites when stationary etc - most of the functions of the old full talex. Don't use any other novus updates, the rider will load in but erase everything leaving you with a brick for example.
pacemaker1000
PostPosted: Mon May 18, 2009 10:19 pm    Post subject: Reply with quote
thanks
ordered the cable Laughing
pacemaker1000
PostPosted: Sun May 24, 2009 11:23 pm    Post subject: Reply with quote
the lead was expensive but worked a treat
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Hardware based GPS SCD Systems All times are GMT + 1 Hour
22.062 (12 Jun 24)
