pEst_29 Occasional Visitor
Posted: Wed Apr 01, 2009 11:06 pm Post subject: The clock is wrong. No daylight saving? |
I used my TomTom Go 730 today after some days of inactivity and when I was preparing a route, I realised it thought it was 1st of January 1970. The time was also 1hr behind. After an hour driving, the time was still wrong. I did a reset and after that, after it got a lock, I could see it had the right date. However, it's still one hour behind! How can I fix this? |
Paul80 Regular Visitor
Posted: Wed Apr 01, 2009 11:23 pm Post subject: |
Adjust the time in prefrenses |
Posted: Wed Apr 01, 2009 11:31 pm Post subject: |
It needs a GPS fix to work out the correct date and time of day for the IQ routes to function correctly After that you need to correct the local time zone as the device uses UTC Time which remains constant all year round unlike our stupid clock based time - Mike |
Posted: Thu Apr 02, 2009 12:43 am Post subject: |
mikealder wrote: | It needs a GPS fix to work out the correct date and time of day for the IQ routes to function correctly After that you need to correct the local time zone as the device uses UTC Time which remains constant all year round unlike our stupid clock based time - Mike |
How do I correct the local time zone? |
dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Thu Apr 02, 2009 12:58 am Post subject: |
Click on the 'Profile' button at the top of this screen. Scroll half way down to where the Time Zone setting field is. Adjust accordingly and save. _________________ David |
Oldboy Pocket GPS Moderator
Posted: Thu Apr 02, 2009 6:33 am Post subject: |
dhn wrote: | Click on the 'Profile' button at the top of this screen. Scroll half way down to where the Time Zone setting field is. Adjust accordingly and save. | The OP is referring to the time on the 730.
It's in Change Preferences | Set Clock.
2nd Page of Menu adjust hours setting by pressing "up" once. Press "Done" twice. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Thu Apr 02, 2009 11:23 am Post subject: |
Posted: Thu Apr 02, 2009 5:41 pm Post subject: |
Oldboy wrote: | dhn wrote: | Click on the 'Profile' button at the top of this screen. Scroll half way down to where the Time Zone setting field is. Adjust accordingly and save. | The OP is referring to the time on the 730.
2nd Page of Menu adjust hours setting by pressing "up" once. Press "Done" twice. |
Blimey I couldn't find that option yesterday! Sure it's there? Will look again tonight...
Thanks! |
Posted: Thu Apr 02, 2009 5:54 pm Post subject: |
You should have 7 or 8 pages of options in change preferences if it's less than this try change preferences/ show all menu options otherwise the clock option might be missing - Mike |
cleggie Occasional Visitor
Joined: Aug 28, 2006 Posts: 36 Location: South Yorkshire UK
Posted: Thu Apr 02, 2009 6:12 pm Post subject: |
I did it manually the other day when the clocks went forward.But just checked today and i turned the clock back an hour first,then i pressed the sync button and it did it to the correct time ie GMT +1 hour.
So it must use daylight savings.
This is for UK
Try it |
Posted: Thu Apr 02, 2009 9:24 pm Post subject: |
Thanks everyone, sorted now. Can't believe I missed that option yesterday, I guess I got too tired to pay attention before I got to the eight page of the Prefs menu! |
Andy_P Pocket GPS Moderator
Posted: Thu Apr 02, 2009 11:11 pm Post subject: |
cleggie wrote: | i pressed the sync button and it did it to the correct time ie GMT +1 hour.
This is for UK
Try it |
It doesn't...
Once you have set the hours yourself, the "sync" button only synchronises the minutes.
Try it by changing the hours to something completely wrong then press "sync". |
Posted: Thu Apr 02, 2009 11:47 pm Post subject: |
Andy_P wrote: | cleggie wrote: | i pressed the sync button and it did it to the correct time ie GMT +1 hour.
This is for UK
Try it |
It doesn't...
Sync didn't work for me. I went to my balcony until I had s satellite lock, then pressed Sync but nothing happened, several times. I don't know if I had to wait quite a lot longer? I just did it manually... |
Daggers Lifetime Member
Joined: Jun 20, 2005 Posts: 1096 Location: Solihull, UK
Posted: Thu Apr 02, 2009 11:48 pm Post subject: |
Andy_P wrote: | Once you have set the hours yourself, the "sync" button only synchronises the minutes.
It's not quite as straightforward as this. If you change the time, then press the Sync button before pressing Done, it resets the hours to what they were before.
However, if you change the time, press Done, then go back and press Sync, no changes are made to the hour. _________________ Garmin DriveSmart 50 LMT-D |
