Pocket GPS World :: View topic - cant connect pda or sd card to latest home?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop
DefenderBLACK
PostPosted: Fri Mar 13, 2009 11:49 pm    Post subject: cant connect pda or sd card to latest home? Reply with quote
Doesnt seem to see my TT7 on my pda? or card if using card reader?
Help said to download home images.zip but cant find this file anywhere?
PAul
PostPosted: Sat Mar 14, 2009 1:34 am    Post subject: Reply with quote
Adding the Home images FOLDER worked for me.
you can download the zip archive of it from TomTom HERE
Unzip it and copy the resulting folder 'home_images' and its contents to the root directory of your SD card.
DefenderBLACK
PostPosted: Sat Mar 14, 2009 1:01 pm    Post subject: Reply with quote
this is now installing ver 1.6 of tt home? have latest 2.5?
still says no device connected?
PostPosted: Sun Mar 15, 2009 2:38 am    Post subject: Reply with quote
Do not understand..... The Home_Images folder from that link should not install anything itself, certainly not Home v1.6.
PostPosted: Sun Mar 15, 2009 9:55 am    Post subject: Reply with quote
Paul, Which PDA are you trying to get the TomTom Navigator 7 application / map working on? - Mike
DefenderBLACK
PostPosted: Sun Mar 15, 2009 10:28 am    Post subject: Reply with quote
its a HP ipaq 3970 running windows 2003.
tt7 is installed on the storage card.
had tt6 installed on there before and tt home saw it okay - could it need the card formatting before tt7 installed and also deleting any tt folders on the ipaq itself?
Paul
PostPosted: Sun Mar 15, 2009 10:40 am    Post subject: Reply with quote
Where did you get the software from as its certainly not intended to be installed/ supported to the hardware you are using? - Mike
DefenderBLACK
PostPosted: Sun Mar 15, 2009 12:45 pm    Post subject: Reply with quote
actually have taken off v7 now as read that the maps are not very good compared to my orginal v6. typical. now my orginal is been funny about installing!!!! Was told when i bought v6 that it wouldnt work on my pda (took a chance) and it has worked fine.
Friend told me to try it as he got it on his htc and said that he had seen you can use it on any pda! which i suppose you can but it
PostPosted: Sun Mar 15, 2009 1:01 pm    Post subject: Reply with quote
TTN7 is only supplied with specific HTC phones from certain phone companies, also it will depend upon which country the unit is sold in as to whether or not it comes with TTN7.
The application is not available to purchase as a standalone, the maps are much more upto date than the TTN6 versions, but thats no good if it won't install, you would also need to purchase a map, which if it didn't work you would get no assistance from TomTom, not even your money back!
Whats up with your TTN6 application? - Mike
DefenderBLACK
PostPosted: Sun Mar 15, 2009 2:10 pm    Post subject: Reply with quote
nothing TBO - except some new roads are missing etc - but thought with it been a later version that it would be more upto date also noticed that you can download updates to roads etc.
Read that v6.75 maps are better than the version 7 but v 8.15 are better than 6.75 !!
PostPosted: Sun Mar 15, 2009 2:12 pm    Post subject: Reply with quote
And v825 is better than all of the ones in your list as that is the current latest map for the Nav units - Mike
DefenderBLACK
PostPosted: Sun Mar 15, 2009 6:56 pm    Post subject: Reply with quote
how do you tell which map version you have?
PostPosted: Sun Mar 15, 2009 7:38 pm    Post subject: Reply with quote
Two ways to do this:
1/ Start the application and tap the sat strength meter, then tap the "version" box, the resultant screen will offer the information you want.
2/ Use windows explorer to view the contents of your map folder, open the file with the extension of .pna using NotePad or WordPad and it will tell you the version - Mike
troywibb
PostPosted: Thu Apr 16, 2009 5:17 pm    Post subject: Reply with quote
I have just found out that the TOMTOM GPS software in my IPAQ is no longer available to update. TOMTOM home won't even recognize my IPAQ. When I use the older version 1.6 it still won't recognize it. I understand that TOMTOM and HP have parted ways possibly causing this issue. I was tols in another forum that there is nothing I can do, but it was suggested to me that I could simply install another GPS software on my IPAQ.
I don't know how to, or where to find the info and software to do this.
Can anyone give me suggestions? Is it just easier to buy a handheld GPS?
Thank you.
PostPosted: Thu Apr 16, 2009 7:02 pm    Post subject: Reply with quote
Welcome to the forum which version of TomTom are you running on your iPAQ and which PDA is it you have? - Mike
Post new topic   Reply to topic    Pocket GPS World Forum Index -> MyTomTom / TomTom HOME Desktop All times are GMT + 1 Hour
22.111 (06 Nov 24)
