Pocket GPS World :: View topic - Second warning on ASH camera manager
ttrevor
PostPosted: Tue Mar 03, 2009 5:40 pm    Post subject: Second warning on ASH camera manager Reply with quote
Just a queston on the Ash10 program settings, I would like to have just a bong on the second warning and not to be shouted at again after the first warning, if I set it 10 seconds for second warning will I just get the bong,??
Iphone x 64gb IOS 11.3.1 / IPhone 6 Plus 32gb IOS 12 beta /Volkswagen Scirocco R 280 bhp /Suzuki Vitara swb vvt+ /Suzuki Jimny special/running Apple Mac Mini / Apple air/ iPhone x /6 plus navigation / Apple car-play
PaulB2005
PostPosted: Tue Mar 03, 2009 5:49 pm    Post subject: Reply with quote
Are you using Voice Alerts?
ttrevor
PostPosted: Tue Mar 03, 2009 5:54 pm    Post subject: Reply with quote
Yes I am Paul!
PaulB2005
PostPosted: Tue Mar 03, 2009 6:09 pm    Post subject: Reply with quote
Then you'll only get voice alerts i'm afraid unless you donate and use the option to seperate the Approach and Overspeed alerts.
See this page
Also for Garmin devices, the *Separate out Approach and Overspeed warnings can be used to create separate POI categories for Approach and Overspeed warnings. This means that where a device supports them, you can have a voice Approach warning and a simple chime Overspeed warning (or even a different message). Note that this option doubles the number of POI categories used, up to a maximum of fifty-eight(!) Some Garmin StreetPilot devices have a limit of around eight-five POI categories, so this is something to bear in mind if you use lots of other POIs.
Even then, you can't control the number of bongs you get, that's down to Garmin...
ttrevor
PostPosted: Tue Mar 03, 2009 6:13 pm    Post subject: Reply with quote
OK thanks Paul I do have the Ash10 full program, thanks for the info
PaulB2005
PostPosted: Tue Mar 03, 2009 6:24 pm    Post subject: Reply with quote
Ah, well there you go. Tick the box and Apply.
tomthompson
PostPosted: Wed Mar 04, 2009 12:42 am    Post subject: Reply with quote
If your using the full ash program then you can have whatever you want as the overspeed sound you just have to create soundfiles with the name overspeed in it ie PocketGPS_UK_Gatso_Fifty_Overspeed. to match the GPX files
Mine is "slow down" for everyone . Brilliant
Asus Zenfone 2 twin sim, Garmin Zumo 550, 660 and pocketgps speed camera database
I keep on learning but they invent new things faster ,How do I keep up ?
ttrevor
PostPosted: Wed Mar 04, 2009 8:45 am    Post subject: Reply with quote
Hi Tom , can you send me a set if possible??
tomthompson
PostPosted: Wed Mar 04, 2009 8:09 pm    Post subject: Reply with quote
I can send them but mine are all .wav and would need to be changed to mp3 files . My 2720 wont do mp3.
If you still want them pm me an email address
ttrevor
PostPosted: Fri Mar 06, 2009 1:57 pm    Post subject: Reply with quote
Ive made some up now Tom, is it correct that it sounds even if you are under the speed limit as mine does Confused
tomthompson
PostPosted: Fri Mar 06, 2009 6:39 pm    Post subject: Reply with quote
mine sound if I am just under the speed limit and of course if I am going too fast . If I am about 4mph under the limit no overspeed warning.
I did try to email them but got a rejection on the email for you !
ttrevor
PostPosted: Fri Mar 06, 2009 7:56 pm    Post subject: Reply with quote
Hi Tom no problem as regards sending the file very strange that, mine seems to sound just below the speed limit I'll give it another go tommorow anyway thanks for your help
spajohn
PostPosted: Wed Mar 25, 2009 10:20 pm    Post subject: Reply with quote
Hi! I notice on this thread that you have successfully added voice files on a Garmin to replace the bongs. I've tried every which way and can't get my voice files to play instead of the bongs - and wondered if you could help ... I've a new Garmin 265WT.
I've paid for and downloaded Ash10's Camera Manager utility - and Garmin POI Loader.
I've created .wav sound files and placed them in the same directory on my PC where Garmin downloads the PGPSW database. I have named the .wav files the same as the .gpx files.
This uploads successfully to an SD memory card on my Garmin.
The cameras show up - but all I get is the bongs!
I have tried adding a new set of .wav files directly into the poi folder on the SD card where the PGPSW database is located - no change.
Thoughts very much appreciated - thx!
PaulB2005
PostPosted: Thu Mar 26, 2009 12:47 am    Post subject: Reply with quote
spajohn - you'll find some questions / answers in this thread This is one of the reasons we discourage asking the same question in multiple threads, you end up with multiple questions and answers. Best to keep it all in one place. Please post any answers in the other thread.
spajohn
PostPosted: Thu Mar 26, 2009 6:23 am    Post subject: Reply with quote
Many thanks - point about multiple postings noted!
