Pocket GPS World :: View topic - NMEA Altitude Reading Problems
Narxis
PostPosted: Mon Jun 14, 2004 5:00 pm    Post subject: NMEA Altitude Reading Problems Reply with quote
Hi all, im writing a GPS application for use on PC / Pocket PC, im reading in NMEA sentences on the serial port from my Fortuna GPSmart BT, all the other figures im reading seem to be pretty accurate except the Altitude, im reading 734m, from a posistion pretty close to see level (OS Maps show between 6-14m above sealevel)
Is there some conversion I need to do to figure out a more realistic Altitude?
Thanx in advance for your help,
Fil
lbendlin
PostPosted: Mon Jun 14, 2004 6:28 pm    Post subject: Reply with quote
Don't even try going there. There is an altitude correction versus the geoid that is transmitted by the sats. Some GPS receivers ignore it, some others factor it in, but the wrong way around, and some others actually get it right. Your program would have to cater for all these eventualities Confused
Lutz
TomTom/TeleAtlas NAVTEQ
DavidW
PostPosted: Tue Jun 15, 2004 12:28 am    Post subject: Reply with quote
My understanding was that the satellites don't transmit any corrections - it's up to the GPS receiver to correct altitudes.
GPS altitude is a bit of a nightmare. Not only do you have to deal with ellipsoid to geoid corrections, which some GPSes handle and some don't (and SiRF based receivers seem to do backwards in NMEA mode - that issue is mentioned elsewhere in this Advanced lounge here), but to get from WGS84 altitude to Ordnance Survey altitude you have to carry out a datum transformation.
Add to that that GPS altitude can be rather inaccurate (the horizontal position error is, by design, rather less than the vertical one) and are you sure you want to do this?
Narxis
PostPosted: Tue Jun 15, 2004 4:51 pm    Post subject: Reply with quote
Hmm sounds like its not quite as simple as I was hoping it would be Confused
Is the change in Altitude easier to work with? Im thinking that for hikers / riders etc the change in Altitude is likely to be more interesting, perhaps, the user could zero the altitude at there starting point, and see how high they are relative to the start point. Smile
DavidW
PostPosted: Sun Jun 20, 2004 2:33 pm    Post subject: Reply with quote
Especially if you're talking about movement within a ten or twenty mile radius, handling altitude as relative to your start position could work very well. If you find you need absolute altitude handling, you can always come back and rework the code later.
UKHABU
PostPosted: Sun Nov 21, 2004 6:13 pm    Post subject: Reply with quote
How products like MemoryMap deal with this is to ignore the height info from the GPSr!
MM has an entirely seperate file for altitude data (after all the actual point you are on the Earth doesn't change). MM then just corellates the latest GPSr live position with the altitude file - the altitude files are *.QED.
My Silva MultiNavigator works differently as the software cross references the GPSr altitude data with an accurate Barometric barometer to come up with a very accurate height - as long as you calibrate it against a known height position eg a Trig point on a mountain top.
GSAK V4.2.2
MemoryMap OS 2004 & V5 Navigator
Navman Pin(Mitac Mio 168)
Navman SmartST Pro V2 & V3
Mitac Mio 558
Skippy
PostPosted: Sun Nov 21, 2004 11:06 pm    Post subject: Reply with quote
The thing to remember is that the altitude problem is with the SIRF based GPS units, other GPS units do actually report the alitude correctly.
You may want to consider an option in your program to ignore the altitude reporting for the broken SIRF GPS units.
Gone fishing!
DavidW
PostPosted: Mon Nov 22, 2004 3:50 pm    Post subject: Reply with quote
I don't know why I didn't post this earlier. There's some fairly detailed commentary on SiRF based GPS chipsets (mis)handling of altitude in this thread and the thread linked to it in my first post.
barryd
PostPosted: Mon Nov 22, 2004 9:21 pm    Post subject: Reply with quote
DavidW wrote:
Especially if you're talking about movement within a ten or twenty mile radius, handling altitude as relative to your start position could work very well. (...)David
I'd be interested to hear how you get on with this. When I look at profiles of round-trip bike rides, the height given for my start point is often 10 or more metres out from the height of the same position at the end of the ride!
Barry Davies
