linknet Frequent Visitor
Posted: Tue Jan 27, 2009 12:21 pm Post subject: |
Added Version 6.02
This should now be fully compatible with both of these versions:
iGO8 PDA Version 8.3.2.64029 dated 7th November 2008
iGO8 PNA Version 8.3.2.64873 dated 13th November 2008
Plus some minor cosmetic changes.
linknet |
Patrick2008 Occasional Visitor
Posted: Tue Jan 27, 2009 2:01 pm Post subject: Please help |
Hello guys,
I can't get the Ultra skin working.
If i select it and iGo will restart i get an error:
FFUIERROR: Unknown object indentifier
Indentifier = [vGetUpdates]
Script "st_Start_init"
command 45
Can someone help me because the ultra skin is the only skin for me. I refuse to use others. And default is nothing compared with the Ultra skin. |
Posted: Tue Jan 27, 2009 4:23 pm Post subject: Re: Please help |
Patrick2008 wrote: |
Which version of iGO8 are you using ?
linknet |
Posted: Tue Jan 27, 2009 4:42 pm Post subject: |
8.3.2.64873
On a TyTn II |
Posted: Tue Jan 27, 2009 4:51 pm Post subject: |
Patrick2008 wrote: | 8.3.2.64873
On a TyTn II |
If you look on page 1 of this topic "LolitaDamore" reports it as working on the same device.
Have you got the correct data.zip for version 8.3.2.64873 ?
linknet |
Posted: Tue Jan 27, 2009 5:03 pm Post subject: |
I supose the data.zip is correct. How can I check it? If i look at the options menu it shows 8.3.2.64873. If i delete the save map on my TyTnII it works again. But as soon as i change the skin to Ultra I will get the FFUI error. With other skins i dont have this problem. But then the other skins are the problem, they all suck. |
Giantbiker73 Occasional Visitor
Posted: Tue Jan 27, 2009 5:11 pm Post subject: |
linknet wrote: | Giantbiker73 wrote: | What does the setting "Pop-Up Second Route Event" do? Doesn't seem to make a difference when settings are changed. |
I've added a descriptive graphic to the website screenshots page.
This fully explains the "Pop-Up Second Route Event" settings.
linknet | Marvellous
Now I understand the setting correctly, wonderful. Thanks for your effort in clarifying.
I've put the 6.02 skin on my TyTnII running version 8.3.2.64029, simulation runs fine. I'm travelling back home tomorrow so this will be a good test (although I strongly doubt the skin going wrong on me, ofcourse).
Will report if problems occur. |
Posted: Tue Jan 27, 2009 5:13 pm Post subject: |
Patrick2008 wrote: | I supose the data.zip is correct. How can I check it? If i look at the options menu it shows 8.3.2.64873. If i delete the save map on my TyTnII it works again. But as soon as i change the skin to Ultra I will get the FFUI error. With other skins i dont have this problem. But then the other skins are the problem, they all suck. |
I'm pretty sure that you are using the data.zip from version 8.3.1.xxx which is not compatible and you will get the error.
Check your PM's
linknet |
Posted: Tue Jan 27, 2009 6:00 pm Post subject: |
I have ckecked my PM |
jkare Occasional Visitor
Posted: Tue Jan 27, 2009 8:18 pm Post subject: |
Hello Linknet,
I'm glad your back.
I have a problem I can not find the menu "3D Smart Zoom settings".
I see on your site in the screenshots but I can not find in the settings on my PDA.
Can you help me
thank you |
Posted: Tue Jan 27, 2009 8:29 pm Post subject: |
jkare wrote: | I have a problem I can not find the menu "3D Smart Zoom settings".
3D navigation map "Tap" then "Tap and Hold" on the right hand zoom button at the bottom of the screen.
linknet |
tekilachat Occasional Visitor
Posted: Wed Jan 28, 2009 9:14 am Post subject: |
Welcome back linknet, I'm very enjoy
I'm Tek', but, this nickname already exist here ;)
we have job to do, french translation, french voice for speedcam ;) |
Posted: Wed Jan 28, 2009 9:45 am Post subject: |
first french translation :
Blocked Roads="Routes Bloquées"
Block Road="Bloquer une Route"
Remove Block="Retirer la route bloquée"
Deleting blocked road.="Supprimer la route bloquée."
Deleting all blocked roads.="Supprimer toutes les routes bloquées."
Find Map Mode="Trouver Mode Carte"
Find Map Mode Settings="Trouver Reglages Mode Carte"
Key Sounds Volume="Volume du Son des Cases"
Next Turn="Prochain virage"
Pop-Up Info Settings="Réglages Fenetre Info"
Pop-Up Info Panel="Panneau Fenetre Info"
Display Visible POI's Only="Afficher seulement les POIs visibles"
Maximum Search Radius="Rayon max. de recherche"
Lane Information Settings="Paramètres pour l'information des voies"
Menu Button Fade Out="Bouton Menu disparaissant en fondu"
Trip Data Overspeed Warning="Signaler un dépassement de vitesse"
Show Speed Limit="Voir Limitation de Vitesse"
Show Speed="Voir Vitesse"
Tilt Up to:="Inclinaison jusqu'à:"
Tilt Down to:="Incliner à:"
Map Full Screen Settings="Paramètres de la carte plein écran"
Second Route Event="Seconde manœuvre"
Second Route Event Show at:="Afficher la seconde manœuvre à:"
Second Route Event Show if Less than:="Afficher la seconde manœuvre si inférieur à:"
Show House Numbers at:="Afficher Numéros Maisons à:" |
Posted: Wed Jan 28, 2009 9:46 am Post subject: |
Quote: | First french translation : |
That looks good, I'll add it to a language file and post it as soon as I can find time.
linknet |
LolitaDamore Occasional Visitor
Posted: Wed Jan 28, 2009 11:46 am Post subject: |
I would only change "Fenetre" by "Fenêtre" |
