Pocket GPS World :: View topic - Saving favourites
Saving favourites
courier
PostPosted: Sat Jan 24, 2009 4:28 pm    Post subject: Saving favourites Reply with quote
If I install an upgraded map will my favourites be automatically transferred from my old map or will I lose them? Any advice would be greatly appreciated. Bernard
PostPosted: Sat Jan 24, 2009 4:45 pm    Post subject: Reply with quote
If you are upgrading to a version 815 map then your Favourites will most probably be lost, best bet is to convert them all to POI locations stored in a single POI Category, this way you won't lose them - Mike
PostPosted: Sat Jan 24, 2009 6:57 pm    Post subject: Reply with quote
A quick "How to..."
Andy_P2002 wrote:
Its a manual process so depending how many favourites you have, it will take a little bit of time.
1 ) First, create a new POI category (Preferences / Manage POI / Add POI category ). Call it "Favs" or whatever you like.
2 ) Then go Preferences / Manage POI / Add POI / Favourite / and select your first favourite.
3 ) Repeat step 2 for each of you favourites.
The POI file will be found in your map folder, called "Favs.ov2" (if that's what you called it). Just copy that file (and its matching .bmp icon file) to your friends machine's map folder and enable it in the manage POI menu.
If you have one of the newer "ONE" models which doesn't allow you to create POI categories on the machine, you can use POIEdit (from http://www.poiedit.com/) to open the old Favourites file and save as a POI file from there, which you can load back on the machine.
A longer "How to.." HERE
22.105 (30 Oct 24)
