Pocket GPS World :: View topic - Profiles
Profiles
Westlothian
PostPosted: Wed Dec 31, 2008 10:29 pm    Post subject: Profiles Reply with quote
Is there a good way to let you see the profile of a route?
Experimenting with the Satmap I can only do this by introducing intermediate points manually. It would be useful it a route profile could automatically insert points every 10m for example.
reklawpete
PostPosted: Thu Jan 01, 2009 11:49 pm    Post subject: Profiles Reply with quote
From the Routes menu select the route you want and press the bottom left button (View). You should then have the route map on the screen and can then again press the bottom left button (Profile) to view the profile. Hope this helps.
Westlothian
PostPosted: Fri Jan 02, 2009 12:56 am    Post subject: Reply with quote
Thanks reklawpete,
I can do this, but for a two point route, the profile is only a straight line.
I want to see the profile between the points without adding more manually.
Westlothian
PostPosted: Fri Jan 02, 2009 12:57 am    Post subject: Reply with quote
Thanks reklawpete,
