Pocket GPS World :: View topic - Traffic and O2 GPRS - Problems
Ains
PostPosted: Thu Jun 03, 2004 12:45 am    Post subject: Same problem with Orange GPRs Reply with quote
Same issues for me using Orange GPRS :
First connection OK (occassionally second as well) then "can't connect to Tom Tom" . GPRS connection still active (able to connect to web sites).
Also, info downloaded seems erratic - several instances of traffic problems not reported (or at least downloaded)
IPAQ 3870
Pocket PC 2002
Nokia 6310i via Bluetooth
Tom Tom 3.01 and latest GPS update
Is there anyway of checking the firmware version of the phone ?
Also, is there any way of getting the IPAQ, Tom Tom and the phone to "reset"`after a GPRS connection ? i.e. to get the whole thing to connect via GPRS, check the info once and then close down until I press "update" again ? Currently this can only be achieved by a soft reset of the IPAQ
Ains[/b]
Trev_H
PostPosted: Thu Jun 03, 2004 12:26 pm    Post subject: o2 (DNS) Reply with quote
I've changed my DNS settings on the IPAQ to server supplied rather than typing in an address. This does seem to make TTT work for a little bit longer, about 5/6 downloads rather than two, but it still stopped working.
Also, o2 traffic stated delays on M25 J29-30, TTT stated nothing.
It might be worth comparing o2 traffic (dial 1200) with TTT as it often seems up-to date.
Trev
tom9851
PostPosted: Thu Jun 03, 2004 1:11 pm    Post subject: Reply with quote
Ains, to check the firmware version of your 6310i key-in the following string... *#0000#
The first line you see on the screen will be your version i.e. V 5.51
Hope this helps
Tom
___________
IPAQ2210/ROM-1.10/LEXAR 32X 256MB SD/Kingston ElitePro 1GB CF
TTN3-V3.03/Wired GPS-V3.03/Globalsat BT-338
deesoft
PostPosted: Sat Jun 05, 2004 2:25 pm    Post subject: Traffic and GPRS Reply with quote
My mobile phone is an Ericsson T610 being used on BT Mobile.
I am having grat difficulty on getting Traffic to work with GPRS. An Email to BT, gets the reply that their service doesnt support GPRS. Yet my phone happily shoes the GPRS Icon when I use WAP.
I have tried various setting on my PDA (HP Ipaq h2210) but wuth NO success.
I can use traffic on a GSM connection, but this obviously is not the idea.
Any suggestions?
MrT
PostPosted: Sat Jun 05, 2004 6:32 pm    Post subject: Reply with quote
BT Mobile does not support Mobile Internet over GPRS which TomTom requires. It only supports WAP GPRS which is not the same. Make a fuss to BT Mobile over this, I have.
DavidW
PostPosted: Sun Jun 06, 2004 3:52 pm    Post subject: Reply with quote
Just to add to MrT's comments, there are several ways the term GPRS is used. Some mobile phone accounts have GPRS over WAP and GPRS for MMS (picture messaging, which uses a WAP setup), but don't have GPRS Internet access. You need the latter for TomTom Traffic.
oisky
PostPosted: Sun Jun 06, 2004 7:19 pm    Post subject: Reply with quote
Did anyone ever come up with a definative answer to this threads problem? As at the moment, traffic is useless to me (unless I want to only use it once at the start of a trip !!)
eddie_vincent
PostPosted: Sun Jun 06, 2004 8:04 pm    Post subject: Reply with quote
I don't know about this update once and then nothing. I quite often get nothing from the start. Can't isolate a definite cause - could it be a memory issue?
Eddie
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
SteveRose
PostPosted: Tue Jun 08, 2004 1:43 pm    Post subject: Reply with quote
Me t0o!
Ipaq 3870 and Nokia 6310i or a 3650!
Steve
RickUK
PostPosted: Tue Jun 08, 2004 2:15 pm    Post subject: Same problem for me! Reply with quote
I also have the 'two update' problem.
HP Jornada 568
Nokia 6100 on t-mobile
Rick.
RichardS
PostPosted: Tue Jun 08, 2004 2:20 pm    Post subject: Reply with quote
To confirm I am also seeing this problem (2 traffic updates, and then nothing more). Same as reported by others, IE continues to work. If I quit TT3, and then restart TT3 (keeping GPRS context active), I get 2 more successful updates and then it stops again.
I am using Toshiba E740 BT, with SE T610, O2 GPRS (using mobile.o2.co.uk as the APN, DNS 193.113.200.200).
SteveRose
PostPosted: Tue Jun 08, 2004 2:40 pm    Post subject: Reply with quote
I have just had this response from TomTom.......
"TomTom Navigator 3 can connect to the Traffic server but after a specific number of traffic updates ‘Cannot connect to traffic server, check your internet connection’ appears in the ticker bar. At the same time it is still possible to open a web site in the Pocket Internet Explorer. After restarting, TomTom Navigator 3 can connect to the traffic server again.
TomTom is investigating the root cause but first analyses show that some GPRS networks do not allow multiple connections from one application in a short period of time. When a solution is available it will be made available as an update on the web site.
With best regards,
The TomTom Customer Support Team"
JamesShannon
PostPosted: Thu Jun 10, 2004 3:38 pm    Post subject: Fix on the way... Reply with quote
I've been helping TomTom resolve this one so I'd expect an updated version imminently. The low number of incidents reported via O2, T-mobile & Orange should also be resolved.
--James
alix776
PostPosted: Thu Jun 10, 2004 4:17 pm    Post subject: Reply with quote
i hbope so a nice man at tomtom said on wednesday that they are looking in to problem and an update will eventually delete
usually i work nights and between 10 and 2am traffic show a 20 min delay wired also shows no problems at birminghamduring rush hour also to the gentle man in the silver focus on tuesday or wednesday morning if you lift the ipaq so you can see the srceen its a lot more use full
sorry the last bits off topic but you never no Laughing
device Lumia 950 xl
matt_e
PostPosted: Fri Jun 11, 2004 11:58 pm    Post subject: Reply with quote
Am getting the same issues with my TMobile connection via T68i.
Only gets 30-60% of traffic incidents (compared with grabbing the updates in the PC cradle). Also, updates lock up for no reason.
Matt
Page 3 of 4
